Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
Need Help With Engine Light!
Old Oct 9, 2009 | 07:28 PM
idrink_v8's Avatar
I had my car tuned awhile back My engine light came on about a week ago and it won't turn off.
I reset it a few times and it turned off but came back on again. What should i do. Oh, I still have my o2 simulator on my exhaust. I wonder if thats the problem? Help?
Old Oct 9, 2009 | 08:15 PM
divine_evo's Avatar
check engine lights are not only for O2 sensors. could be another problem.
divine_evo's Avatar
can you read out the check engine light code.
Old Oct 9, 2009 | 08:39 PM
idrink_v8's Avatar
Im sorry it not Check Engine Light Its Sevice Engine Soon light. Its
off when i reset it then it comes back on like a few hrs later when im driving.
Old Oct 9, 2009 | 08:53 PM
js06evoix's Avatar
So....
Take the keys to your Evo... and the car itself.. and return to the nearest Mitsubishi dealership. Your Evo card has been revoked.
The check engine light IS the Service Engine Soon light. See how both of them say engine in them? Methinks they must be the same.
Also, if you insist on keeping your Evo, you can take it to any parts store where they can attach a scanner to the computer and see what the "Service Engine Soon" light code means.
Old Oct 9, 2009 | 09:02 PM
mikiblueeyes's Avatar
Lol that actually makes sense
Originally Posted by js06evoix
So....
Old Oct 9, 2009 | 09:06 PM
js06evoix's Avatar
Thanks! Wasn't sure how easy to understand it would be
Old Oct 9, 2009 | 09:11 PM
idrink_v8's Avatar
So....
Yea, maybe ur right.....NOT!
Old Oct 9, 2009 | 09:13 PM
jester81783's Avatar
since it only comes on after a few hours, its most likely one of your obd II systems non continuous monitors, so it could be a few things like the cat, either o2 sensor, evap system, etc, but it should not be a misfire code or anything that is immediately harmless. That being said, pull the code and then get back to us. Pulling a battery cable almost never "fixes" an issue, but believe me, when i had my rx-8, i tried it all the time!!! lol glad its gone
Old Oct 9, 2009 | 09:21 PM
idrink_v8's Avatar
Is it necessary to keep the o2 simulator on after your car is tuned?
Old Oct 9, 2009 | 09:29 PM
yahu's Avatar
^depends on how it was tuned (and probably who tuned it!). Are you currently MAF-less, then? If they used speed density then you probably don't need it. Take it off and see what happens as the IX tends to respond well anyway.
Old Oct 9, 2009 | 09:33 PM
idrink_v8's Avatar
yea, ill take it off 2morrow morning see what happen.
Old Oct 9, 2009 | 09:34 PM
js06evoix's Avatar
O2 simulator is for the O2 sensor by the catalytic converter. If you have no cat, then yes you need to have the O2 simulator and will always need it. Unless you purchase and install the O2 extender
Old Oct 9, 2009 | 10:00 PM
fuzzydoodle's Avatar
Right, I think the best information given in this thread is the most obvious.
GET AN OBD TESTER AND PULL THE CODE
Strangely enough, this has been the most consistent information for a CEL....
Funny thing is, is it tells you what you're problem is.
Old Oct 9, 2009 | 10:16 PM
amsevoixmrse's Avatar
I have AMS TBE with test pipe and before the tune I had o2 simulator.
Later I had my car tuned at Drift Office . I was told by ER that Drift Office was probably using their map.
After tha tune Drift Office told me I can take simulator off my car since it was flashed and I don't need it .
I don't have CEL issues.
