Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
Issue with front idler pulley (60k service) Help!!
Old Nov 4, 2010 | 12:19 PM
M8NSTER's Avatar
I can't get the front idler pulley off because the bolt runs into the frame. I'm not sure why this is. I've tried lowering and raising the engine (top passanger side motor mount is off).
Any help would be greatly appreciated!
Old Nov 4, 2010 | 12:46 PM
F0RSAKEN's Avatar
Pic no worky....
Talking about serpentine belt? To remove that, just gotta pull passenger wheel, use 1/2" ratchet or breaker bar (no sockets, it's a square hole), and lever counter clockwise.
If that's not what you're talkin about, then no idea lol.
Old Nov 4, 2010 | 01:00 PM
M8NSTER's Avatar
Weird, I can see the pic.
No, I have the s-belt off. It's one of the pulleys on the s-belt.
Old Nov 4, 2010 | 01:10 PM
BellyD's Avatar
Bottom left ?
Old Nov 4, 2010 | 01:19 PM
M8NSTER's Avatar
^Correct, bottom left pic.
Old Nov 4, 2010 | 02:20 PM
M8NSTER's Avatar
Yay, it's out!!!!!!!!!!!!
I lowered the engine about 1.5-2" and it came out!
Old Nov 4, 2010 | 02:42 PM
javicracer's Avatar
sometimes this idler bolt is a *****!
Old Nov 4, 2010 | 04:04 PM
Ryan.Kauz's Avatar
needs a bigger mallet for re-install.... just a warning. use something about this big and you will be fine:
Old Nov 11, 2010 | 01:51 PM
drmartens68's Avatar
I'm about to do the same project..... I'm replacing the tensioner, belt, and the pulley. What all did you pull to lower the motor enough to get the pulley bolt out???
Old Nov 11, 2010 | 07:42 PM
M8NSTER's Avatar
You have to remove the motor mount on the top passenger side (3-14mm bolts and 1-19mm). Put a piece of wood on a Jack and put that under your oil pan. Put a little pressure on it and the motor mount will come off easily. Lower the Jack till you can get the pulley's bolt out.
Old Dec 3, 2010 | 03:16 PM
flymx771's Avatar
I removed the upper motor mount and it still isn't low enough to get it out. Anyway to get the motor to go any lower? Please help!!
Old Dec 3, 2010 | 03:29 PM
M8NSTER's Avatar
Just keep lowering the engine with the Jack. Go little by little until its low enough to get the bolt out.
Old Dec 3, 2010 | 03:30 PM
meckert's Avatar
Back out the two bolts in the front cross member, the one that runs front to back with the frt motor mount--that allows the motor to drop that extra 1/2inch to pull that bolt out easily---just did it myself. Dont need to remove the bolts just back them both out and it wil drop.
Old Oct 17, 2011 | 07:56 PM
screamsofreason's Avatar
What is the part on the top left called?!?! Thanks.
Old Oct 18, 2011 | 08:52 AM
M8NSTER's Avatar
I think it's the serpentine belt auto tensioner.
Lightsaber
Jun 7, 2017 03:58 PM
mines5
Jan 4, 2017 07:04 AM
RallySport Direct
EvoX 'For Sale' External Engine / Power
21
Aug 7, 2014 10:00 AM
apiazza2010
Sep 6, 2012 08:51 PM
