Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
Which BOV to get?
Old Aug 26, 2011 | 10:40 AM
M8NSTER's Avatar
Which BOV to get?
Need to get a new BOV cause my Greddy S is leaking.
These are the two I'm looking at. Would like to get feedback on these or any other BOVs people like. (I recirc, have just bolt ons and ER tune - 25lbs)
http://www.extremeturbosystems.com/V...00GT-GT-R.html
http://www.maperformance.com/go-fast...gfb-t9033.html
Old Aug 26, 2011 | 11:27 AM
yahu's Avatar
neither
Old Aug 26, 2011 | 11:28 AM
BellyD's Avatar
Someone got lazy.....
That's an informational response Dan!
Old Aug 26, 2011 | 11:33 AM
yahu's Avatar
he asked which two to get and I said neither.
I'd say APS; I think Keenan was selling one, and I believe Derek (dbsears) is too
Old Aug 26, 2011 | 11:34 AM
Joey B's Avatar
Veteran: Air Force
Dan's just a yahu...that's why LOL
I'd point you to https://www.evolutionm.net/forums/se...samco-bpv.html
and
https://www.evolutionm.net/forums/ev...lly-works.html
I have the APS which worked great when I was still with a MAF and pretty stock. It does not leak one bit, but does VTA (does recir as well as VTA) a little under heavy boost.
Old Aug 26, 2011 | 11:36 AM
yahu's Avatar
^exactly...on all counts.
I ninja edited my previous post with more info, btw.
Old Aug 26, 2011 | 11:37 AM
nemsin's Avatar
CBRD recently posted a thread about leaking blow off valves https://www.evolutionm.net/forums/ev...ur-valves.html
They seem to like the APS one http://www.airpowersystems.com/us_spec/evo/bov/blow.htm
and the Synapse, which motoiq did a huge write up on
http://www.motoiq.com/magazine_artic...ter-valve.aspx
Hope this helps.
Old Aug 26, 2011 | 11:39 AM
boostedwrx's Avatar
I like the Synchronic (the pop can size one.. although hate the size.) Has held 33+ psi and doesn't leak or cause surging. Can run in vta or recirc.
Old Aug 26, 2011 | 11:42 AM
Wayne99gsr's Avatar
Forge recirculating FTW!!
Old Aug 26, 2011 | 11:48 AM
M8NSTER's Avatar
Thanks everyone, except Dan, you're an a$$. I said or any other BOVs! (Edit: guess you did say APS - tho you're still an a$$ lol)
I will look at the APS and Samco too.
Old Aug 26, 2011 | 11:52 AM
Joey B's Avatar
Veteran: Air Force
DAMN!!! Stupid ninja's! Creepin and crawlin everywhere.
Old Aug 26, 2011 | 12:00 PM
dbsears's Avatar
APS has the best drivability and holds 35+ psi...I happen to have one that is almost new I would part with
Old Aug 26, 2011 | 12:01 PM
yahu's Avatar
I would have also said Synchronic as people seem to like that too, but I haven't had personal experience with it. Again, you should be able to pick up the APS for relatively cheap from some users that are selling theirs. Derek's likely has very little mileage and probably is almost brand new. I think I caught him turtle-waxing it once.
*edit - I didn't even see his post before mine when I made this one. I believe Jared and others that road race swear by the APS
Old Aug 26, 2011 | 12:11 PM
03Evo8DTC's Avatar
I had zero problem at 30lbs on VTA with the APS and the synchronic i had a huge lot of problems with.
Old Aug 26, 2011 | 12:30 PM
CBRD's Avatar
APS is not really available anymore-
Cobb is nice, but we've had some leak
Synchronic compact in pull style with outter port only works well, it isnt perfect- but I think it is the best option currently available!
cb
