Rims , tires & more.
Old May 10, 2013 | 10:39 PM
LUNARFX's Avatar
I personally think 22" wheels would be overkill to say the least on the Sports. I'm considering a set of staggered wheels on a set of 20" concave Volk Racing, Vossen, or Rohana wheels, knowing not being able to rotate the tires clearly from front to back, and of course understeer. Since I don't plan on ever autocrossing, or even 1320 racing, I have a different mind frame on the set of wheels for ours.
Old Jun 5, 2013 | 01:26 PM
ChrisHostos's Avatar
Originally Posted by Hiboost
For the Outlander Sport SE:
Stock Wheel: 18x7 (25 lbs)
Stock Tire: 225/55-18 Goodyear Eagle LS-2 (29 lbs) 27.8" Diameter
Optional sizes that are the same or close to stock diameter:
215/70-16 on 16x6.5, 16x7 (cheapest size for snow tires, stock ES size)
225/60-17 on 17x6, 17x6.5, 17x7, 17x7.5, 17x8 wheels (Good snow tire size)
245/50-18 on 18x7, 18x7.5, 18x8, 18x8.5 wheels (Good summer/all season tire size with wider contact patch)
245/45-19 on 19x7.5, 19x8, 19x8.5, 19x9 wheels (lower profile, better response, harsher ride)
245/40-20 on 20x8, 20x8.5, 20x9, 20x9.5 wheels (lower profile, better response, harsher ride)
Going with the wider wheels will improve the response of the tire assuming you are in within the size ranges it can mount on. As the wheel gets bigger diameter the weight will increase, but usually the tires will drop in weight a bit as there is less sidewall so it's not always a killer of performance if you stick with lighter weight wheels. The Tirerack.com has some great info as far as comparing all the tire brands and what will fit on your car.
Are the bold numbers highly suggested and a risk of not fitting?
im personally contemplating a 19x9.5 or 20x9.. but according to the numbers above... if the bolds mean they fit.. i may be at risk of not fitting.
Old Jun 5, 2013 | 01:28 PM
staggered? as in a 20x9 front and a 20x10 rear? or as in a staggered offset so you have a deeper concave in the back.. but same width? 20x9 off sets 15R and 35F?
Old Jun 5, 2013 | 06:34 PM
Burtonrider1002's Avatar
EvoM Moderator
Staggered might also mean (usually on RWD drag cars) something along the lines of a 16" rim on the front, and an 18" on the rear. This is often referred to as "rake".
Old Jun 5, 2013 | 06:55 PM
Oh definitely. . Im aware. I highly doubt any OS owner will use a rake style for any reason. My concern was with the owners "staggered" want.. and if he has 4x4.. it may be damaging. Instead of a same width staggered offset.
Old Jun 5, 2013 | 07:48 PM
EvoM Moderator
I was just expanding on the explanation. No idea if he was considering doing it or not lol. I think he was talking about staggering the front wheels smaller so they don't rub when turning.
Old Jun 5, 2013 | 08:34 PM
LUNARFX's Avatar
Just catching up for the day, and yes this is what I meant. Ours is FWD so no harm to the AWD component when we don't have that feature.
Only true enthusiasts would remember or be educated in this unlike most of the people in today's world. Kudos to you sir.
Not so much so they don't rub, but yes, I wouldn't want the wheels to have any restrictions in turning. Nothing drives me crazier than seeing a Monte Carlo on 26" wheels that can't do a U-turn. I also understand I'd have plenty of understeer, but realistically, with 2 DSM's on hand, and a Galant VR-4 project, this is the last option of the family that will ever see an autocross event.
If I can get away with going with a square setup, then of course I'd go that route so I can rotate the tires all the way around. I'd love to get fitted with a nice set of wheels, but that will probably be the last thing on my very small mod list especially if I end up doing an air ride setup. I'm really hoping the guys here who have been talking about their suspension upgrades work it out, so I can see options. So far, the guy in India has the best and tried and proven setup that I'm admiring, but that belongs in another thread.
Old Jun 5, 2013 | 09:02 PM
EvoM Moderator
U MeEN U DNT liEk mi rimmz?
http://www.cardomain.com/ride/271627...shi-outlander/
More in the link...
I mean I can respect his "creativity" and the "hard work" put in, but wow... Not quite my style.
Old Jun 5, 2013 | 09:17 PM
eeesh. may be consdiered as "A lot more wrongs, than rights... " By hey to each their own. Maybe is was a movie car for tokyo drift.. Fast and furious. lol... or He/She; thought so.
Old Jun 5, 2013 | 09:29 PM
LUNARFX's Avatar
The custom exhaust tips are about all I can handle...maybe not even that. No offense, but I'm actually glad it was completely debadged so no one knows what it is or was.
The funny thing is that the title in his CarDomain says "Lowrider." Is it me, or is it not even lowered? But hey, I'm not here to knock someone's hard work. Just not my cup of tea either.
Old Jun 7, 2013 | 06:43 AM
Hiboost's Avatar
The bolded tire sizes typically list the bolded wheel sizes I listed next to them, the other factor is choosing the right offset of the wheels so that as they get wider you run a lower offset to push the away from the inner suspension components. The tires themselves will be what actually rubs in the fender wells if you size them wrong or go too wide.
9.5" wheels are probably as wide as you would ever want to go, you would have to check with the tires you plan on running to see if they would work with a wheel you choose. The Tire Rack lists all the specs of the tires on what wheels they can mount on and probably could steer you to choose the correct offset and tire sizes to get what you need.
Old Jun 7, 2013 | 06:57 AM
Greatly appreciate the well detailed info. I will be patent when ordering in the coming weeks. I dotn want to jump on something i will not like because it was the right fitment. thanks again.
Old Feb 7, 2014 | 04:40 PM
Go5586's Avatar
Bringing up old thread here guys need some help. Looking to get aftermarket 18" on my SE. How did you guys handle the TPMS sensors in the tires?
Old Feb 7, 2014 | 04:49 PM
Go5586's Avatar
My wife bought me these (in 18in) for a present. She did a lot if research beforehand with a friend who kind of does this stuff but when I got wind of it I wanted to cover all of my bases. I plan on using my tires from current OEM rims and just throwing them on the new ones. Only 15k on them now. Is there anything else I need to purchase? Specifically concerned with TPMS sensors. Thanks guys!
http://www.tirerack.com/wheels/resul...rSpecial=false
Old Feb 12, 2014 | 11:40 AM
LeoFama617's Avatar
Originally Posted by vinniefan15
20" vct romano
245/40/20 nexen 3000 tires
ordered online from vittorewheelandtire in nc - check them out on ebay.
Shipped , wheels, and tires $1575
wheels were mounted on tires...and a set of lugs came with it
pleasure to deal with
i was planning on getting 20" but what was the offset for the 20" you got?
nismo3183
Northeast Region
May 6, 2016 04:22 PM
lukaszuka
Outlander Sport
24
Jun 13, 2015 10:42 AM
SpardaVR4
Dec 21, 2012 05:37 AM
Darkdragon4862
69
Aug 22, 2012 10:03 AM
LancerEVA06
Jul 7, 2009 09:31 AM
