Project Blackout
Old Jul 20, 2013 | 10:48 PM
  #136
Burtonrider1002's Avatar
EvoM Moderator
How does the alternator handle the compressor?
Old Jul 20, 2013 | 11:05 PM
  #137
RA012124's Avatar
Fine I guess, it's a 12V, 16amps compressor. Never had any electrical issues in any of my other previous vehicles, Rav4, Juke, Mustang either. The Outlander Sport would be the least of my alternator worries since we have regenerative braking on top of everything else.
Old Jul 21, 2013 | 12:25 AM
  #138
EvoM Moderator
The regen braking is what scares me. A replacement alternator is like $1,400
Old Jul 21, 2013 | 01:49 AM
  #139
RA012124's Avatar
Why? Isn't that what our thousand year warranty is for?
Old Jul 21, 2013 | 03:52 AM
  #140
EvoM Moderator
Not if they determine the air pump was "directly responsible" for the alt. failure. Or it happens after the warranty expires.
Old Jul 21, 2013 | 05:03 AM
  #141
mRVRsport's Avatar
From: Out towards the countryside of Dallas, TX (USA)
It's a legitimate concern.
But, with our regen alternators capable of producing 130 Amps (max.) [spec LINK, for RVR] I don't think Wes's 12V/16A compressor will kill the alternator.
Burton,
Keep in mind he got the trim model that doesn't have all the other optional electronic dodads that we have, so his electrical system is under less strain than ours to begin with.
Unless Wes decides to blare out that train horn for an hour or two chasing other people away, his compressor wouldn't kick in all that much (is my thinking).
Old Jul 21, 2013 | 06:20 AM
  #142
EvoM Moderator
A 3/8"air line dumping air like that will empty a tank that small in a new York minute lol. I suppose he won't really be using it all that often though.
On a plus note, if you ever have a low tire, you can swap a tire chuck on the line and fill er up!
Old Jul 21, 2013 | 07:51 AM
  #143
LUNARFX's Avatar
I'm surprised you didn't try to pull that off in the engine bay area. I don't think we could sacrifice any more space in the trunk area. We've really liked all the things we could tote with it, but hey, you manage everything very well with all your gadgets!
Old Jul 21, 2013 | 06:17 PM
  #144
RA012124's Avatar
I think it might be physically impossible to put everything under the hood, and it wouldn't be practical to have to pop my hood open when I need to use my tire chuck.
Old Jul 21, 2013 | 06:36 PM
  #145
LUNARFX's Avatar
Ah, I didn't know if you could miraculously fit the compressor behind the front bumper somehow. I've only been under the car once to change the oil. It would most likely be too tight.
Old Jul 21, 2013 | 07:06 PM
  #146
mRVRsport's Avatar
Nice vid. That's impressive of the sound distance with those horns.
Our stock horn(s) truly sounds like toys. Now I will have to find something better.
Old Jul 21, 2013 | 11:44 PM
  #147
EvoM Moderator
You can't make it so ONLY the train horn sounds?
Old Jul 21, 2013 | 11:56 PM
  #148
RA012124's Avatar
You can, but I've never done it before. I hate electrical wiring stuff, but I'm guessing you would need a more complicated switch that accepts 1 power source (horn wire) then 2 toggle positions.. One for each horn output.
Found it
I guess I'll return this switch since it barely fits into the blank button.
Old Jul 22, 2013 | 11:09 AM
  #149
BTBean's Avatar
Found it
I wonder if we can order switch blanks from Mitsu for the switches in the panel? I've often thought about doing switched LEDs but don't like those nasty rocker switches. I single throw that is exactly like the ASC switch would be awesome if they had blanks (or maybe I could order the ASC switch and plasti dip it).
Old Jul 22, 2013 | 12:08 PM
  #150
EvoM Moderator
I'm sure you could find them, it's all about finding the right key words and actually putting in the time.
