infected's 2013 RVR SE AWD
Old May 7, 2014 | 12:24 PM
  #136
DhiJay23's Avatar
Originally Posted by DhiJay23
We actually have the same Bluetooth functionality so I dont why its not working on my part.
Gave the Pioneer a call and Tech Support told me to try a manual configuration. Will try and do that once my wife arrive.
Old May 7, 2014 | 02:17 PM
  #137
infected's Avatar
Let us know how it goes!
Old May 9, 2014 | 07:45 AM
  #138
DhiJay23's Avatar
Not to jacked up your thread but i got the steering wheel control all working. Thanks for your help.
Old May 11, 2014 | 12:10 AM
  #139
fat_lemon's Avatar
Originally Posted by infected
I always thought the factory reflectors on the lower bumper were rather tacky, especially with the pizza slice orientation.
I picked up some LED reflectors the same size as the factory reflectors without the pizza slice look.
There is a 10mm nut on each side holding the reflector in place.
I had to drill a small hole to run the wiring.
Almost there...
And the end result. I wired these to the running lights only. The LED is 2 stage and has the option to illuminate even brighter when braking. That wasn't the look I really wanted and I'm happy with just having functioning reflectors that only come on and stay lit at night without the pizza look.
hi did you have a pic of how you have make you're wired cause i want to do the same but I'm not very sure where to make the connection, i'm very visual...? thanks and sorry for my crappy english i'm from montréal ....
Old May 12, 2014 | 03:45 PM
  #140
TEXAS TRAVISTY's Avatar
like it
Old May 13, 2014 | 07:59 PM
  #141
infected's Avatar
I tapped into the stock tail light harness. I believe there is also three wires if I remember correctly. Black, green, and green/black. Black is for ground, green is for the brake light, and green/black should be for the driving lights. Give that a try!
Old May 15, 2014 | 09:56 AM
  #142
SicLanEvo's Avatar
where did you get the reflectors? I was looking for this but could only find them for the pre2013 rears..... i can get them all wired up when i do my rear fog as well!
Old May 15, 2014 | 09:21 PM
  #143
infected's Avatar
I picked them up when I was in China. Not sure what to search for if you were to look for them on ebay.
Old May 16, 2014 | 07:40 AM
  #144
SicLanEvo's Avatar
its probably rear reflector leds ASX or something. i havent looked in a awhile but many options for the pre 2013
Old May 16, 2014 | 07:57 AM
  #145
ChrisHostos's Avatar
http://www.aliexpress.com/item/High-...853131613.html
Old May 16, 2014 | 10:15 AM
  #146
SicLanEvo's Avatar
nice find, they also double as a extra set of brake lights..... could be good!
Old May 16, 2014 | 10:47 AM
  #147
wingless's Avatar
Background: My name is Terence
From Calgary eh? Nice car terrance!
Old May 16, 2014 | 07:16 PM
  #148
infected's Avatar
Nice find! Those look to be it. Mine are the exact same but I didn't want the second set of lights to illuminate so I left the wire unattached.
  #149
infected's Avatar
Haha, thanks!
Old Jun 15, 2014 | 08:44 PM
  #150
infected's Avatar
48. SSR Type C Wheels
Installed some new light weight rollers for summer. I'm still on the stock Yokohama Geolanders that originally came with the car. There is a mild stretch but I plan to go wider once these wear out. So far no issues with this setup. Also grabbed some new TPMS sensors and Muteki SR48 lug nuts.
The plan is to refinish the wheels and pick up better sized tires once the Yokohama's are chewed up. I have the replacement stickers ready but I think that won't happen for another 1-2 years.
16x7 +30 front
16x8 +35 rear
