infected's 2013 RVR SE AWD
#242
Thanks. Yes the RVR is still around, haven't really had much time to update but it's more or less been the same. Glad to see another Calgarian!
#243
You've done a lot of great jobs infected. And thanks for the writing. I've got '13 RVR GT with 710W stereo. My wife was not happy with the narrow slot stereo unit with the GT.
Changing to the double din headunit isn't a problem for me as I have done same for my '03 Honda Odyssey. I haven't done such to the RVR as I am afraid it might void the 10-year warranty because I would disconnect some original equipment (Forsgate thing).
Did you get consent from Mitsu beforehand to be sure that such wouldn't void the warranty? And is yours with the 710W subwoofer (I guess no)?
Thanks.
Thanks.
#244
I did a little bit research of the parts needed, all the accessories cost over 400 dollars, not counting the head unit yet. Guess I will pass doing this for GT.
Probably I will pick a SE trim with already a double din receptacle, and without the useless Fosgate, so the only accessory would be just the metra harness.
Thanks anyway and have fun.
#245
Thank you for the write ups and updates infected! I just bought a 15 outlander sport after owning a 2000 wrangler for 15 years(still own just retired as dd) and after 1 week thought of how un-modifiable the outlander is. Thank you for proving otherwise. You do some very clean diy work. How did you go about debadging it? My Jeep i just had to peel stickers off.
#246
Thank you for sharing these steps.
However, if I may, I have an observation: the way the wire crosses over the A pillar, it seems to be interfering with the side-curtain airbag's deployment path. I will route mine in-between the A pillar cover and the windshield.
#247
Your rear led lamps, I got the same on my ASX 2.2D automatic, but immediatly the ABS/ASC lamps started to flash, and I could start the car with my startbuttom without depressing the brake. I found out that the led aftermarket rear lamps misses a 1000ohm resistor between 2pins to the connectors in the lamps. Installed the resistors and all started to work as orignal rear lamps.
#248
I wasn't planning on doing any exterior lighting work at first but with all the snow and stormy weather we've been experiencing as of late, I simply could not put up with the stock headlights any longer. I couldn't see!
I chose 5000K this time from experience. 4300K wasn't anything unique and 6000K would be too blue at times and begin to strain my eyes.
The kit from VVME is direct plug and play. I've always had positive experiences with them.
Attachment 275896
Ballasts with built in igniters, bulbs, brackets, and hardware.
Attachment 275897
There is an option for a relay but I opted out thinking the low beams will be on full power anyways during the night. The factory wiring should be capable of handling a 35W HID kit compared to the stock 55W halogen.
Stock passenger vs HID driver.
Attachment 275898
I hid the ballasts behind the splash shield under each corner of the fender. The wires tuck away nicely and there are extra holes on each side to mount the bracket. Gotta always appreciate a clean install!
Attachment 275899
Attachment 275900
That's all!
Attachment 275901
Attachment 275896
Attachment 275897
Attachment 275898
Attachment 275899
Attachment 275900
That's all!
Attachment 275901
#250
Hey'all just a quick question here. I did realized that I bought a 55W instead of 35W 6K HID and was wondering if I need to use a relay to make a sufficient supply of power? I noticed too that you mention that the regular bulbs are 55W's so not really sure if plug and play scenerio applies to my situation. Thank ya'll.
#251
Weathertec is expensive for mats, but I definitely have these on my list. I love the utility. (Sorry so late, just joined).
2013 Lancer SE
2015 Outlander Sport
2013 Lancer SE
mRVRsport
Outlander Sport
968
Feb 25, 2021 11:58 AM
