transmission problem
I have a 2011 Mitsubishi Outlander Sport that has transmission problem, it's stuck on the first gear, wont shift and has a P0868 error code, transmission fluid pressure low. any suggestion how to fix it.
Thanks
Thanks
OMG DO NOT DRIVE! Drain and replace the Fluid\Filter. Then Pray and maybe flush again after running it for 30 minutes. Hopefully the clean fluid and filter allows you to limp it until you can replace the car. Good Luck!
Have you checked the transmission fluid level yet?
https://www.700r4transmissionhq.com/...shi-outlander/
Cole Crouter
Mitsubishi TC-SST Discussion
Jun 15, 2023 12:16 AM
Jpenley
Mar 22, 2016 10:26 AM
DouggieVee
10
Oct 16, 2013 07:49 PM
