Originally Posted by Ayoustin
(Post 11961592)
The little tiny one? I have no clue, I can definitely measure it and find it online tho
(Post 11961585)
DRIVETRAIN PORN
Originally Posted by V.8MR
(Post 11961599)
Now we're talking! Looking good Austin, maybe we can meet up for some track day hoon next fall. Starting to sound like we'll both be in a position with our Evos to facilitate it.
(Post 11961598)
that thing seals really well. I'm not going back to the OE part.
(Post 11961600)
Oh yes absolutely! NCM is the only track that's really between us and I absolutely don't think my car will pass their 105dB sound limit there unless I can get creative. But I can always bring the Civic or another track may line up better with our schedules.
(Post 11961604)
Meh wouldn't bother me to head up to Gingerman or RA, Autobahn. Or if you want to head this way and try out the Ozarks International Raceway. In any case its sure to be a great time.
I picked up these old carbon bars from a Nascar auction recently and decided I could make strut bars out of them. Total assembly weight is 2lbs vs the stock bar's 7lbs and makes working on the rear of the engine bay way easier since it can be removed with just the two bolts. Pretty pleased with how it came out. If anyone is interested in one I have 5 to sell so shoot me a message.
https://cimg1.ibsrv.net/gimg/www.evo...21cc06b473.jpg https://cimg2.ibsrv.net/gimg/www.evo...a954b49e74.jpg https://cimg3.ibsrv.net/gimg/www.evo...ce4f6c34ab.jpg https://cimg5.ibsrv.net/gimg/www.evo...c31ca650fd.jpg https://cimg6.ibsrv.net/gimg/www.evo...c7de54a9d1.jpg https://cimg8.ibsrv.net/gimg/www.evo...84ed424323.jpg |
95% done with my custom rear sway bar. Designed some custom mounts that Dallas machined. Speedway bar and arms. Rough calculator math says spring rate adjustment range should be 300-500ish lbs/in. 1.25" bar with 0.25" wall thickness can go up or down in thickness if I need more or less rate. Just need to drill the holes in the arms for the endlinks and it'll be done. A bit porky at ~16lbs but it's about as low and rearward as can be so I don't mind. Still unsure if the two bolts in the subframe will be enough to handle the load but only one way to find out really.
https://cimg0.ibsrv.net/gimg/www.evo...4023558cfc.jpg https://cimg1.ibsrv.net/gimg/www.evo...3e72302fdd.jpg https://cimg2.ibsrv.net/gimg/www.evo...740b5b2787.jpg https://cimg3.ibsrv.net/gimg/www.evo...5ffa818795.jpg https://cimg4.ibsrv.net/gimg/www.evo...891c7de210.jpg |
Been a minute since I've updated. Car is hiding in storage again, which kind of sucks but that's life. Biggest (expense) hurdle is getting the gearbox setup figured out. Going to chuck in the PAR 3rd and 4th straight cut gears so I don't have to worry about a trans failure, just trying to decide what I want to do for 5th. This may not seem straightforward but here we go.
At the moment I have the following variables to consider:
And here's what all of these look like with the 8000RPM redline and 24.7" tire. in order of JDM, Evo 9, Evo 8 (too big of a jump from 4-5) Open to any input. https://cimg1.ibsrv.net/gimg/www.evo...452683a9a7.png https://cimg0.ibsrv.net/gimg/www.evo...5c25d7139d.png https://cimg9.ibsrv.net/gimg/www.evo...5202299941.png |
What are you planning on doing with the car these days? That should dictate the mile an hour you need at the top of 4th and 5th.
(Post 11969972)
By the way I'm back up in Chicago again, shoot me a text next time you're up in the area for a visit. |
The Jdm 5th is amazing at the track. The TT car we built last year has a tre built trans with the Jdm 5th. Any trans I have jon build for a race car moving forward will have it.
I don't see any mention of a final drive? I'd put a 4.31 final drive in it..
Originally Posted by Meathooker
(Post 11969983)
Originally Posted by LetsGetThisDone
(Post 11969995)
Here's what 4.31 and JDM 5th looks like: https://cimg0.ibsrv.net/gimg/www.evo...fc56d30912.png |
theres this trans on ebay with upgraded 3rd & 4th gears. I dont know but could be better match for the stock 5th?
https://www.ebay.com/itm/29568885108...Bk9SR8z50pibYg |
