The evolution of my Evo IX RS Wicked White
i had same issues with my s2k ball joint boot. i used fiber glass heat wrap and it worked good. might do the same thing here. those boots are cheap enough to replace every season if need to though, they were $15 + shipping for the set.
i picked up these RB stainless pistons and seals from my sponsor.
ss pistons - http://www.shop.motorsportsperforman...per-BM-41P.htm
seals - http://www.shop.motorsportsperforman...rs-BM-41BS.htm
OE 46mm pistons = 0.18 lbs, RB SS = 0.225 lbs; .045 difference
OE 40mm pistons = 0.14 lbs, RB SS = 0.19 lbs; .05 difference
that's a total of 0.19 lbs (1/5 lbs) difference for all four pistons for one caliper.
oem dust seals all burned and cracked
opening up the calipers
caliper split in half
oem pistons next to stainless pistons
use compress air at the bride port and a used pad underneath to prevent one piston from coming out complete and not allow the other one to come out.
remove the oem dust seals
remove oem piston seals
clean out caliper
new stainless pistons and dust seals ready to go in
lubricate the pistons with some brake fluid so they slid in easy
all four pistons are in and ready for reassemble
clean out caliper
