The evolution of my Evo IX RS Wicked White
Old Jan 5, 2012 | 07:39 PM
  #121
Bnjmn's Avatar
Who are your going to run against in TTS? Did anyone enter in the NE last season? Or is Tim moving too?
Old Jan 5, 2012 | 07:45 PM
  #122
drunkoffjuic's Avatar
Very nice build man.
Old Jan 5, 2012 | 08:39 PM
  #123
honda-guy's Avatar
John Robbins ran TTS last year and will run TTS this year. Tim will probably move to TTS and some others might move to TTS also. i just want more freedom modifying car.
Old Jan 15, 2012 | 10:23 AM
  #124
hyp36rmax's Avatar
+Awesome!
Old Feb 7, 2012 | 09:59 PM
  #125
Solo-Wing06's Avatar
impressive +1
Old Feb 29, 2012 | 02:59 PM
  #126
killerpenguin21's Avatar
did you DIY that splitter? any pics of the process to make it? looks very good.
Old Feb 29, 2012 | 03:09 PM
  #127
honda-guy's Avatar
yes, i made the splitter. i've been meaning to get some pics up for it but don't have the time. i'll get around to it eventually. got some other projects coming up soon for the RS.
Old Mar 15, 2012 | 10:14 AM
  #128
honda-guy's Avatar
having some fun chasing my friend in the s2k at Summit Point Main last weekend.
http://www.youtube.com/watch?v=5vGPoWk_xdM
http://www.youtube.com/watch?v=NP_Y5it_3EU
Old Apr 26, 2012 | 04:49 AM
  #129
honda-guy's Avatar
got the headlight duct done. now i need to build an air box for it.
also got front canards on thanks to TougeFactor for hooking me up with them.
Old May 2, 2012 | 12:06 PM
  #130
WRX_PWNER's Avatar
this is a awesome thread, very interesting build.
Old May 2, 2012 | 12:32 PM
  #131
B.J.@ToxicFab's Avatar
Nice headlight duct, looks great! I will probably end up doing the same once I remove my ACD stuff. What did you use to seal the headlight once the duct was installed so it doesn't leak?
Old May 2, 2012 | 04:35 PM
  #132
honda-guy's Avatar
^ i use black RTV silicon sealant. just put a bead round the flange and squish it in, then wipe of the excess.
here's some description https://www.evolutionm.net/forums/ev...ight-duct.html
why are you removing ACD, or relocating? i wouldn't mind relocating it to the back for better weight distribution.
Old May 4, 2012 | 07:20 AM
  #133
Removing ACD...with everything gone I'll drop around 35 lbs...I have a Stage 1 Shep Non-ACD T-case in the garage with a Quaife LSD waiting to go in...
Old May 7, 2012 | 06:01 PM
  #134
honda-guy's Avatar
some pics from Watkins Glen last weekend running with BMWCCA
Old May 9, 2012 | 03:31 PM
  #135
honda-guy's Avatar
upgrade the power steering cooler so i can remove the hard line and have more room for oil cooler up front.
fittings for the oil cooler
upper bracket for the oil cooler
oil cooler up front and power steering cooler mounted
i have this Setrab 40 row oil cooler but it's going to take some modding the rad support to fit it. i didn't have time so i just put the stock one up front for now.
tap this Defi oil temp sensor into oil drain plug because i had to use the port on the oil filter housing for FP oil feed line for turbo.
