EVOlutionary's LR2.2L MIVEC Build - Titanium Inside :)
Old Sep 17, 2013 | 07:30 PM
  #211
EVOlutionary's Avatar
Well, I'm stuck until I figure out what to do. I have the seat back all the way touching the roll cage main hoop cross bar an the pedals are going to be too close for comfort. I am in need of the best solution. The options I've though of so far include:
- moving the seat forward and using the OEM pedals, scrapping the $800 pedal box I just imported from Europe
- cutting out parts of my new cage and rewelding them (harness bar from straight to curved, move the gusset tube by my head, etc) so can move the seat back 2 more inches. Also would need to modify/change my seat rails
- cut/modify the firewall to move the pedal box forward 2 inches
- some other option I have not yet thought about???
Any thoughts???
One good thing - car is back to "rolling chassis" status for the first time in about 1 year!!
Old Sep 18, 2013 | 06:11 AM
  #212
Bassicfun's Avatar
my two cents (about all it is worth too) would be to modify firewall to move the pedal box back. As I was reading, that was my first thought before reading through your options. Good Luck!
Old Sep 18, 2013 | 07:04 AM
  #213
Lancerboy89's Avatar
I would agree with bassic modify the firewall or is there a way to trim the pedal box so it can move back two inches? sry if that a dumb question not to familer with the pedal box thing, but just adding my .02 best of luck
Old Sep 18, 2013 | 10:34 AM
  #214
Bruzewski's Avatar
Something you might want to look in to. It would save some weight as well!!
http://www.nlm.nih.gov/medlineplus/e...cle/002965.htm
Old Sep 18, 2013 | 10:35 AM
  #215
Bruzewski's Avatar
Double post...
Old Sep 18, 2013 | 11:21 AM
  #216
Ouch!!
Old Sep 21, 2013 | 12:15 AM
  #217
griceiv's Avatar
Any thoughts???
I'm curious why you think you need a floor mounted pedal box? if it's the dual master cylinders you're after there are easier solutions. like this.
https://www.pegasusautoracing.com/pr...asp?RecID=9162
that said, i'd leave the cage and firewall alone.
Old Sep 21, 2013 | 09:42 AM
  #218
Two main reasons. First is to move the seat back as far as possible. Where it is currently mounted (as far back as I can go with this cage design) my shoulder is behind the B-pillar. Next build I'll have the main hoop moved back even further. . .
Second reason is weight and cleaning up the engine bay. . .
Any downsides to the pedal box vs OEM setup? Besides fitment/cost?
Old Sep 24, 2013 | 10:02 PM
  #219
My new iPhone cover thanks to Bruzewski!!
Old Sep 24, 2013 | 10:11 PM
  #220
Mocking up the steering column.
Old Oct 19, 2013 | 06:22 PM
  #221
SDevo13's Avatar
Hey. Curious as to why you didn't go with this set up:
http://www.rallynuts.com/motorsport-...l-box-kit.html
You just add one of these in:
http://www.rallynuts.com/motorsport-...ted-cover.html
Would have been around $200 more expensive than your current set up, but would have given you the room you need.
Old Oct 22, 2013 | 08:57 PM
  #222
I did see that. There are a couple reasons I did not go with that setup. First - I am trying to keep my a$$ as low in the car as possible, and I thought that raising my feet 2-3" to clear the master cylinders and plumbing may not be very comfy. Second - it seemed the routing of the brake lines with this setup would be more difficult.
HOWEVER - after attempting to my alternative mounting scheme using the E30 box - I think I may just buy the Evo-specific box and see which one works best for me. Heel height does not seem to be as big of issue as I thought it may. Then I can simply sell off the unused box to recoup some of my expense. Wouldn't be the first time I bought two of something and sold one at a loss
One more note - after checking out this pedal box setup I would REALLY like to see a high end Tilton or AP box in person to see just HOW different they are in terms of fit and quality. I wish I could afford a $5000 AP box like the Tilton Interiors Evo. I also wish I could afford a $25000 Holinger sequential trans with a $10000 ECU/shifter setup. . . not today, but I'll keep putting in the long hours at work so I can afford whatever I can. . . which leads me to my latest acquisition
Old Oct 22, 2013 | 09:38 PM
  #223
SDevo13's Avatar
Sent you a PM
Old Oct 22, 2013 | 10:36 PM
  #224
Here are a few parts of my new dry-sump oiling setup:
The Peterson multistage pump assembly:
The Peterson oil reservoir:
The new billet front cover that deletes the OEM oil pump:
Old Oct 23, 2013 | 04:38 AM
  #225
siikEvo92's Avatar
Niiiiice.
