All Hail Megatron Build - MAP 2.4LR
Levar install that double pumper!!!!!!!!!!!!!!
As you fellahs already know, I had a little oil mess to clean due to not having the backside of the valve cover sealed. As stated, I opted for the Simple Green and water approach mainly because I feared brake cleaner would have damaged the powdercoated parts in the engine bay. Yesterday, I sprayed down the parts of the engine bay that had oil on them and water them down. I must have done this at least 4-5 times as I wanted to ensure that all of the oil was completely off. Since it is sunny and hot here in Arizona, I decided to let everything dry off overnight and then take the valve cover off the next afternoon. Fast forward to this afternoon, about 2PM, I go outside and start to remove the valve cover after seeing that there was no sign of oil anywhere in the engine bay. "Good job" I am thinking until I take the coil-on-plug system off and there I see water having a good conversation with my spark plugs. "Oh dang" I am immediately thinking at this point. There was a small puddle of water (hardly visible) in the 1st, 3rd, and 4th cylinder. But there was a good amount of water in the 2nd cylinder. "OK" do not stress and just dry the water out as best as possible. So I used Q-tips and shop towels to get the water completely dried and I am starting to feel good about things until I take the valve cover off and I see an oil mix with a hint of water. Now I am starting to really stress. I completely dried up the cylinder head thinking that was the end of the issue until I realized that oil passes through the cylinder head and into the shortblock. The biggest unknown that I have at this point is: What, if any, water is now in the shortblock?
The timing of this is terrible as I go out of town early Wednesday until the 22nd of September and now the car will just sit in my driveway. From a preventive perspective, I am going to drain all of the oil out of the car but what else can I do? Is there something that I can spray or wipe on the cylinder head in order to prevent any potential rust? Is there anything I can pour into the shortblock (either prior to or after) I put the new oil in? I already have new spark plugs that will go in at the same time. I just hope that I have not destroyed my shortblock with less than 1,000 miles on it.
you could always "act" like you are doing a compression test which would "spit" the remaining water out of the engine
a little bit of water wont kill it anyways, its when ur applying a load to the engine when it does.. since water doesnt compress, but heat does cause it to evaporate and eventually dissipate
I doubt that a substantial amount of water got into your oil and even if it did, it should just settle below the motor oil in your pan (oil is lighter). I am assuming that you did not run the motor yet? But replacing the oil and spark plugs should take care of it...
Thanks, my friend. I feel confident that things will be fine.
