Rev.olution Build. Holy Moly!
Old Jul 30, 2012 | 05:53 PM
  #76
C130flyer's Avatar
Old Jul 31, 2012 | 10:01 AM
  #77
C130flyer's Avatar
Old Jul 31, 2012 | 11:39 AM
  #78
Drifting Away's Avatar
wow.....but thats not the first time Ive heard of that happening...
Old Jul 31, 2012 | 11:51 AM
  #79
C130flyer's Avatar
Old Jul 31, 2012 | 11:57 AM
  #80
REV.olution's Avatar
This never got fixed.
Old Jul 31, 2012 | 12:05 PM
  #81
C130flyer's Avatar
Sierra motorsports = EPIC Douche-baggary
Old Jul 31, 2012 | 02:12 PM
  #82
batty200's Avatar
UPDATE: As of 8/12/09, the FP 5R cams and the FP5RI/FP11E cam set for the Mitsubishi Evolution 9, will only be available for purchase in pairs.
That is a proper set of cams. A collapsed lifted is from something else like improper install not the Cam grind.
Old Aug 4, 2012 | 10:27 PM
  #83
J_Striker's Avatar
How does one improperly install a lifter as to collapse it?
And on a side note, I think if I were to use a cam as big as the FP11, I'd be using solid lifters. As luck would have it though, I will never need a cam that big.
Old Aug 5, 2012 | 06:21 AM
  #84
batty200's Avatar
If the lifter is not bleed and cleaned and refilled properly it can cause it to collapse. Usually a collapsed lifter will fix itself eventually but waiting for it to pump up can get annoying. I had one collapse and it took three weeks of daily driving to fix itself. My buddy was driving up the driveway so we could pull the cams and replace it and it stopped right as he was about to get out.
Old Aug 7, 2012 | 12:52 PM
  #85
>BlazinEvo<'s Avatar
holy moly is right I love it!
Old Aug 7, 2012 | 01:06 PM
  #86
J_Striker's Avatar
I've read here on evom of bleeding down, cleaning and refilling a lifter as outlined in the service manual, and I've also read to just bleed them down.
The lifter that you had collapse, what way did you install the lifters? And by doing it that way, did you cause it to collapse by doing it incorrectly?
Back to the build thread, the point is that the cam wasn't what it was soposed to be and 2 lifters collapsed. I hope it all gets sorted by c130flyer soon. Sounds like he's doing a great job getting rid of the gremlins.
I can't wait to see it when it's done. I'm going to be afraid to sit in the passenger seat of this thing.
Old Aug 7, 2012 | 04:58 PM
  #87
batty200's Avatar
At that time I bled them but didn't refill them. They are noisy that way for a while but they won't lock open and cause bent valves. Now I rarely bleed them because by the time I finish doing everything else with a Cam install the lifters bleed themselves back down from spring pressure and they are quiet. Not the right way but it has worked for me. Good luck on the build. Those seer some HUGE cams!
Old Aug 10, 2012 | 12:02 PM
  #88
Originally Posted by C130flyer
Jeremy@ Sierra Motorsports = liar
He sold Aaron a set of used FP5r cams.
Turns out that the exhaust cam is an FP11 exhaust cam.
Jeremy you are now officially on BLAST congrats
This shop has now been legally and communally exposed. If someone would cheat a spiritual leader,your morals must be completely shot.
In other news, Modular Turbo fixed my lifters, and my new cam will be in Monday.
Old Aug 10, 2012 | 06:05 PM
  #89
C130flyer's Avatar
Old Aug 27, 2012 | 11:10 AM
  #90
J_Striker's Avatar
C130flyer...... What else did you find? Is she running good?
