"Darwin" build - Take 2
Old Sep 13, 2012 | 06:15 PM
  #31
Mid_Evo's Avatar
Update.. got the car finished up and everything ready to drive it .. got her cleaned up .. and at about 4 took her out to put some miles on her .. did some serious driving got about 300 miles on her and she just responded so well to everything .. turbo sounds happy, engine feels strong, trans smooth.. and the few psi of boost i threw at it .. we just loved, need about 40 more miles and then ill be set for my tune on friday
getting done up by my tech for taking my keys home lol
1st drive
cleaning her up
Old Sep 16, 2012 | 01:39 PM
  #32
Mid_Evo's Avatar
ok so time wrap up this build thread ... got the motor all broken in .. too down to JMS to get the tunes on friday .. had some work done, did a double pumper walbro 400/255.. buttoned her up and threw her on the dyno .. she made 575WHP and 500TQ.. it got late so we decided to do the pump gas tune on sat .. so i crashed with a buddy and went to the shop the next day .. this was a long day.. in between working on other cars, my tuner kinda tosses the notion at me .. hey if you want to try and go for 600 on speed density nows the time to try it out ..i agree and we get to work on setting her up for SD .. so JMS being the bad *** shop they are .. we strap the car down at 1am and get slamming on the tunes .. they promised me id get tuned that day so they made it happen .. 1st pull picked up instant power .. 588/495... car sounded strong .. we kept at it .. goal was 600, we ended up just shy on the dyno with 593/508.. car was pulling strong. we then took her for a road test .. drained the gas and threw in the poison .. made 471 on pump gas .. not bad for a conservative gad mileage tune lol. we finally got her off the dyno at 4am.. JMS is an amazing shop and stood by the name and work like no other .. cant recommend this shop more highly .. they are the best. all there is to it. oh and 25 mpg is too bad for a 600 hp car lmao .. cant complain .. SD conversion was a totally success .. car runs amazing and smooth as hell.
break in over tune ready!!
chilling pre tune
dyno RD1
Preped for SD
Final Numbers on SD E85 and 93
Old Sep 16, 2012 | 05:26 PM
  #33
jmcmill3's Avatar
congrats, glad she's back up
Old Sep 16, 2012 | 05:42 PM
  #34
Mid_Evo's Avatar
Thanks man, i appreciate it...cant wait to take it to the track and see how she does
Old Sep 16, 2012 | 09:02 PM
  #35
jmcmill3's Avatar
def a 10 sec car- traction permitting.. some other jms cars w/ #'s close to yours were pretty deep in the 10s
Old Sep 16, 2012 | 09:35 PM
  #36
Mid_Evo's Avatar
hell yea 10s all day .. should be an issue at all .. i was doing 11.5 with 410 lol .. so this should net be a problem at all .. launching is a whole new game now though .. that turbo gets off the line way different than the stocker .. so gotta work on that, but once i work out all the things with the set up .. itll be low 10s for sure
Old Sep 16, 2012 | 09:52 PM
  #37
Mid_Evo's Avatar
oh i forgot .. as a final touch to the build thread, here is the most complete and up to date mod list for the car:
Omarcessivo Built LR 2.0
Omarcessivo Built transfer case
JMS SD Dual Tune
GSC S2 Cams
GSC Beehive Valve Springs
5 Angle Valve Job
ARP Head Studs
Wiseco 1400 HD 9:1 Pistons
Manley Turbo Tuff Rods
Eagle 4340 Forged Crank
ACL Tri-Metal Bearings
Mitsubishi BSE
Fluid Damper
Dejon 4in Intake(for long trips, no intake most uses)
FP Black
Injen Intercooler Piping
AMS FMIC
S2 68mm Throttle Body
Triple Ported Stock Intake Mani
Perrin BOV
Spoolin’ Up COP Kit
NGK Cooper Plugs
Gates Timing & Balance Shaft Belt
Gates Serpentine Belt
AEM Fuel Rail
Fuel Lab FPR kit
2150cc FIC Injectors
JMS Double Pumper
E85 Walbro 400/255
MAP o2 Dump
AMS TBE
TS Motor Mounts
Exedy Triple Disk
5-Speed Swap
Buschur Short Shifter
TS Shifter Cable/ Base Bushings
Quaife Diff for T-Case
JMS 2-Piece Drive Shaft
TS Drive Shaft Bushings
Rear Diff Mod
Excessive Performance Rear Diff Bushings
Mishimoto Radiator
AEM AFR
AEM Oil Press
AEM 50psi Boost
GReddy Turbo Timer
GrimmSpeed 3-Port EBC
Megan Racing Coilovers
Whiteline 24mm Rear Sway
Whiteline Adjustable Endlinks
Hawk Ceramic pads
Power Slot Rotors
Stoptech Stainless Steel Brake lines
Old Jun 28, 2013 | 08:34 AM
  #38
Mid_Evo's Avatar
THIS STARTS THE LATEST UPDATES !!!!!!!!!!!!!
UPDATES
Wow, I really left this out of date for a long time .. Lady Darwin has been through some serious changes since this point and it is time to bring this thread up to date !!!!!!!!!! so here we go !!!!!!!!!!!!!
Ssssssooooo 1st off we have the new clutch .. out with the POS exedy triple and in with the Quartermaster 8-Leg Race clutch with pull to push conversion and hydraulic TOB
Hub/Disks eating themselves .. not cool .. 2nd time this happened ...
The New Sexy
Much better hub/disk design
Hydraulic TOB
Now on to the Shattered 4th gear in the stock 5 speed and built trans swap
just some of the 4th gear teeth haha
new sexy trans
and now the new toy T3 PTE 6466
Braced Mani
All DONE ..with install
Old Jun 28, 2013 | 08:46 AM
  #39
Mid_Evo's Avatar
Quick Vid of a pull after tune
Old Jun 28, 2013 | 08:54 AM
  #40
Mid_Evo's Avatar
So next update we have isnt the good kind
... was out racing .. and ran into some serious issues ... I was running a GSXR 1000 and at 180mph my head lifted and it blew both the radiator hoses off the radiator ... and at 180 MPH that is no fun .. esp with 10 bikes that i was raping behind me haha... so i tore it down and come to find out not only did the head lift .. the HG, head and block melted ...
the head is TOAST, the HG DONE, and block is gonna be ok after being decked, and the rotating assembly is 100% nothing bent. broke, or spun .. so im in the process of tearing it down now and bringing her back to life !!
So lesson learned .. dont reuse standard ARP head studs 3 times haha and expect them to be happy with 41 psi and 750 hp ...
Old Jun 28, 2013 | 09:07 AM
  #41
Mid_Evo's Avatar
then not too long after .. new head came in ...my fully built and ported Curt Brown Race head and IM came in .. and hone to hone the block then send block to be decked
Old Jun 28, 2013 | 09:18 AM
  #42
Mid_Evo's Avatar
And before I knew it the rest showed up !!!!!!!!!!!
GSC S3 Lyfe <--- yup with a 'Y"
off to the machine shop we go
New TB .. they sent the wrong one but here the box .. TB pic some later S90 74mm !!
decided to black out a bunch of stuff
Blocks all done and now we BBUUIILLDD!!!!!! Not going to lie this was my solo 1st motor build ever .. and I was nervous especially building for 800-850 whp !!
Old Jun 28, 2013 | 09:28 AM
  #43
aggieEVO's Avatar
Holy smokes. I can't even imagine how much you've had to put into the different setups on this car!
Best of luck to a fellow Texan. I'll be watching this thread!
Old Jun 28, 2013 | 09:29 AM
  #44
Mid_Evo's Avatar
My buddies car thinnking hes cool like the evo haha
The Old sleeper Fp Black Engine bay VS the new "Black Hole Bay"
Old Jun 28, 2013 | 09:36 AM
  #45
Mid_Evo's Avatar
haha yea man, it kills me .. ive ran some very rough numbers and including the car and every thing ive down down to every tune, change, bolt etc its around $70,000 makes want to throw up but i love this damn car and the pride and passion i have just makes it all worth it .. and thanks man I appreciate it itll be all wrapped up here real shortly !!
