mitsuorder's 4g69 experiment
Old Sep 13, 2013 | 06:14 PM
  #196
mitsuorder's Avatar
I really appreciate it man. My goal primarily was to prove the 4g69, probably now the most widely available Mitsubishi 4g iron block in the world, as a viable high horsepower solution. Now we have three proven block options for the ct9a chassis and many across the globe already with this engine have a recipe for some power no matter what car it's in
As I've said before this is full disclosure so if any have any questions I'm completely against the smoke and mirror tragedy that has been suffocating this community.
Old Sep 22, 2013 | 08:40 AM
  #197
brett@evogb's Avatar
Nice build thread ,looks great
Old Sep 22, 2013 | 12:26 PM
  #198
mitsuorder's Avatar
Thanks Brett. Just excited to drive this thing again soon How's everything going on your side of the world?
Old Sep 23, 2013 | 04:48 AM
  #199
Hi yeah its all good I'm still trying to learn your forum and will post a build thread of our demo car and do a intro to ho we are . I havent really heard much of the 4g69 sounds interesting which car does it come from ? We use the 4g64 block and it seems to hold over 1000bhp without issue
Old Sep 23, 2013 | 07:08 PM
  #200
Shade08's Avatar
Hey, just went through your whole thread again. Great stuff man, great stuff this gives me hope! Hopefully I'm as successful.
I do have a question, a reason why I was going through your thread again. (Besides all that sweet fab work)
what flywheel did you use? A 69 or 63 flywheel. Also, any issues with the Evo's clutch? I'm assuming the transmission bolts right up, like on the 64 blocks.
Old Sep 25, 2013 | 09:55 AM
  #201
mitsuorder's Avatar
That's outstanding Brett. If you have any questions about the forums don't hesitate to drop me a line. Can't wait to see the thread. Let me know when it goes up. The 4g69 is found in the Lancer, Galant, and Outlander. Mine came out of an '05 Lancer Ralliart specifically.
Old Sep 25, 2013 | 09:59 AM
  #202
mitsuorder's Avatar
Shade08,
I used the 4g63 flywheel supplied with the Exedy triple cerametallic clutch I'm running. My 4g69 came out of a car with an automatic transmission so there was a hub for the flex plate pressed into the flywheel end of the crankshaft. Just used some good packing grease, some wadded up paper towels, and a couple of solid smacks with a hammer and it came out.
Old Sep 25, 2013 | 08:03 PM
  #203
Shade08's Avatar
Thanks, man.
Old Oct 25, 2013 | 06:09 PM
  #204
doncarbone's Avatar
Apart from proving the 4G69's worth, are you at any type of advantage utilizing the shortblock from the 4G69 versus the 4G63 one?
Old Oct 29, 2013 | 07:38 AM
  #205
evo10.5t's Avatar
mitsuorder how has she been holding up any issues? I just got a hold of a 4g69 block 2.4 build on its way!
Old Nov 6, 2013 | 08:03 PM
  #206
mitsuorder's Avatar
In regards toto comparing to athe 4g64, 2.4 litres of displacement without the need for adustable cam gears, water pump modification/spacer. In regards to a 4g63, a much less expensive block/crank combination are topical advantages I can come up with.
Old Nov 6, 2013 | 08:10 PM
  #207
mitsuorder's Avatar
The car has been sitting in the States as I have been out of the country finalizing my move. Currently setting up container transport for it here. No issues other than two bent passenger side wheels due to the border town infrastructure of San Antonio just a few days before I left in August. The replacements should be in soon from the great guys over at Forgestar
Old Nov 7, 2013 | 09:47 AM
  #208
doncarbone's Avatar
Did you get a new crankshaft or get it nitrided for extra strength?
Old Nov 16, 2013 | 04:58 AM
  #209
mitsuorder's Avatar
Used the oem 4g69 crankshaft that came with my block. It checked out as perfect and utizing it made this more easily duplicable.
Old Nov 16, 2013 | 06:16 AM
  #210
vgm10's Avatar
Nice build....
