Evolution 2 wide body for WTA - pic heavy
Old May 10, 2014 | 04:59 PM
  #151
dougmo's Avatar
also been working on a sump upgrade (unfortunately no dry sump yet)
new designed oil pick up ands pan
Old May 10, 2014 | 05:02 PM
  #152
dougmo's Avatar
and finally for now, I removed the old steel 1/4s off by drilling the spot welds out, this should make for a nicer fit of the fibreglass ones.
the f/g ones are 2.2kgs so a big of weight saving along with better tyre clearance.
also while its off I can cover in the wheel arch so air pressure doesn't build up in the boot like it has done in that past, it was like a big sail.
also de-dagged the inside of the head to help with oil return to the sump.
Old May 11, 2014 | 06:05 AM
  #153
Evo2372's Avatar
Awesome work mate!!!!
Do you think you will have it ready for 2014 Nats Winton/Deca August 22-24th???
I really hope so as I am very looking forward to seeing this beasty in action.
Old May 11, 2014 | 07:33 AM
  #154
Yogi_B's Avatar
The only thing I can fault is that lockwire, the aircraft mechanic in me feels sad looking at it.
Sorry, I'm just very picky when it comes to lockwire these days as I do it all the time.
Old May 12, 2014 | 04:47 AM
  #155
dougmo's Avatar
yep I should be there depending on when my second child is born (due on the 21st lol)
duly noted mate, far from my finest work
Old May 16, 2014 | 01:13 PM
  #156
BuiltforSin's Avatar
Read the whole thread. What an amazing build. Cheers!
Old May 16, 2014 | 05:13 PM
  #157
dougmo's Avatar
thanks mate
Old May 30, 2014 | 03:38 PM
  #158
Zmann42087's Avatar
just want to say I really enjoyed reading through this build thread. I am a DSM owner, so obviously EVOs I, II, and III have a special hold on me. Your build reminds me a bit of Alex Grabau's (Dent Sport Garage) EVO here in the States.
Old May 31, 2014 | 03:54 PM
  #159
dougmo's Avatar
thanks mate, I have always liked the pleasure evo, great build.
work continues on fitting the quarters today and then I got over excited and removed the old roof which I didn't plan on doing for some time, another few kgs saved there
I also had an old head chopped up to see if any port improvements could be made
Old Jun 1, 2014 | 04:20 PM
  #160
555R's Avatar
That's a lot of bad *** work going on there. Before you went wide body I'm interested what did you use as the front lip spoiler on your early pictures.
Old Jun 2, 2014 | 03:45 AM
  #161
dougmo's Avatar
cheers
its lawn edging, its flexible plastic and comes in different widths, that was 100mm
Old Jun 9, 2014 | 06:47 PM
  #162
Ironchief's Avatar
Wow, a lot of work into this car, it's good to see a 2 around once in a while, not many of them.
Old Aug 16, 2014 | 05:56 PM
  #163
dougmo's Avatar
fast forward two months and we have made some good progress leading up to WTAC 2014
ill summarize:
new engine is built and back together on the stand, a few small upgrades from last year;
now 86mm bore
a much better port job on the head
larger exhaust cam
ATI balancer
GTX35 compressor wheel in the S259 turbo and a .85 turbine housing
new sump
Old Aug 29, 2014 | 08:23 PM
  #164
dougmo's Avatar
got a few new bits...........
new style front arms
new front crossmember in cro mo
Old Aug 29, 2014 | 08:24 PM
  #165
dougmo's Avatar
roof and quarters back on
