TSComptuned 2014 on going build thread
Old Aug 28, 2014 | 10:15 PM
  #196
tscompusa's Avatar
Glad to share. Hopefully it helps someone else in the future.
Old Aug 30, 2014 | 05:47 PM
  #197
tscompusa's Avatar
Few pic updates.
Old Aug 30, 2014 | 07:25 PM
  #198
batty200's Avatar
What is this sorcery?! Hahaha.
Old Aug 31, 2014 | 04:21 AM
  #199
MICHAEL1's Avatar
4g64 block?
Old Sep 4, 2014 | 03:11 AM
  #200
tscompusa's Avatar
normal measurements i do when building.
Old Sep 4, 2014 | 03:13 AM
  #201
tscompusa's Avatar
Originally Posted by MICHAEL1
4g64 block?
yes im putting the 2.4 back in temporary while i get the 2.3L ready.
then once the 2.4 comes out i will sell that to a customer of mine then put the 2.3 in.
gonna set the boost around 35-36psi on the 2.4 and see what numbers i get. i think at
35psi its gonna make around 850whp.
gonna put it on flex fuel and use it as a test car also to show how it works before i offer it to customers.
Old Sep 4, 2014 | 03:43 AM
  #202
tscompusa's Avatar
Few more pics. will have it going by this weekend again.
Not a fan of how any of the freeze/expansion plugs were installed so i popped them all out and put in fresh OEM and painted over them. I use a high-tach gasket sealant then i set the plug in properly how its designed to go in past the bevel. If its not pushed in past the bevel it will come out prematurelly. Look at how OEM are seated and that's how they need to be.
This is not the correct way:
So out you go:
Proper tools to get the job done:
After seating new plugs etc. Its still hard to believe these pistons have mileage on them. they look like new
Long block again:
Almost there!
Old Sep 4, 2014 | 05:23 AM
  #203
czum09's Avatar
Awesome build. Great info!!!
Old Sep 4, 2014 | 06:22 AM
  #204
Migsubishi's Avatar
Ha, you install the long block w/o manifolds too huh!
Looking good!
I wish I got the SB crank, but Manley themselves steered me away from it for the power level we play at. I see yours is just fine, oh the frustration.
Old Sep 4, 2014 | 09:18 PM
  #205
tscompusa's Avatar
Thanks!
Looking good!
Thanks!
SB = standard billet? Or super light?
Its on some very very high HP evos 900whp+
I had the super light weight billet on my car, I just swapped it for a standard heavier (downgrade), but i think it needed stiffened up for what I'm going to do with the car. so In that case (upgrade)
Old Sep 5, 2014 | 08:23 AM
  #206
Migsubishi's Avatar
Originally Posted by tscompusa
Thanks!
Thanks!
I'm sorry I meant the 190120BSLW, they told me that the crank will flex after 500ft lbs of torque. They said it's more of a design for road race engines.
I have the next lightest one, it's knife edged 190120B but not as light as the SLW.
The crank in these pics is the one I have, but I think you have the SLW in your other car and that's the one I want!
Old Sep 6, 2014 | 05:11 AM
  #207
tscompusa's Avatar
This one had the SLW also. I sent you an email.
Old Sep 6, 2014 | 07:48 AM
  #208
badev0's Avatar
Your builds threads are always the best. Very good clear pictures and always really informative.
Old Sep 6, 2014 | 09:36 AM
  #209
Migsubishi's Avatar
Got it, thanks!
Old Sep 8, 2014 | 05:07 AM
  #210
tscompusa's Avatar
Thanks Scott!
