rrstlevo's dd project...
Old Mar 3, 2015 | 03:18 AM
  #91
tscompusa's Avatar
Sooner or later we will get the car tuned. This thing just doesn't want to give in easy. LOL.
Old Mar 3, 2015 | 03:22 AM
  #92
tscompusa's Avatar
Originally Posted by STLEVOIX
Wow! Thats alot of cars to tune in the meantime while he has been fixing all the bugs!
When do you think you can have him tuned and done? Sounds like everything is back together and working correctly now. I want to go for a ride in this thing already!
I tune a lot of stuff for sure. I had to start doing full builds now and more mechanical, because I noticed my body started to not like me just sitting on a chair 24/7. Now that im working doing full builds, i feel much better.
Have to mix it up. I'm just thankful i can do all these things and have multiple skill sets to allow me to.
I'll have him tuned and completed as soon as the car stops breaking every part on it.
We got the basics of his tune done, now we just have to do the remainder power tuning.
I'm glad he chose me to tune it, because I feel i really helped motivate him to not give up on the car & am pointing him in the right direction to get it all sorted out.
Old Mar 3, 2015 | 03:33 AM
  #93
Kevin Troy's Avatar
You must have serious crankcase ventilation problem if the dipstick is coming out and turbo leaks oil on the intake side..
Old Mar 8, 2015 | 09:38 AM
  #94
benevento7's Avatar
lookin good
Old Mar 17, 2015 | 10:05 AM
  #95
STLEVOIX's Avatar
Any updates?
Old Mar 28, 2015 | 03:04 AM
  #96
Evo9_Dubai's Avatar
Great thread, and I thought I had issues
Looking forward to an update
Old Mar 28, 2015 | 01:26 PM
  #97
doubleSUSTANON's Avatar
So was it a bad turbo that caused oil inside the pipes, TB?
Old Mar 29, 2015 | 02:04 PM
  #98
NICOSLOW's Avatar
Great build, sorry to hear about all the bugs. It's been probably 2 years or so since I've dealt with Tom from Tscompusa, but every time I have dealt with him has been a total pleasure.
Old Apr 4, 2015 | 10:26 AM
  #99
rrstlevo's Avatar
Failed turbo was pushing air into the crankcase somehow and also pushing oil into the intake. I had to pull the intercooler, all piping, tbody and intake manifold and clean them.
Dip stick isn't popping out anymore.
Boost leak tested to 45 psi and only thing leaking was the boost leak tester
Almost finished with 93 tuning.
Old Apr 4, 2015 | 11:21 AM
  #100
STLEVOIX's Avatar
Good to hear! How are the numbers lookin on 93? How much boost ya running?
Old Apr 4, 2015 | 11:25 AM
  #101
rrstlevo's Avatar
460ish hp right now at 30 psi according to VD. But no official numbers since we aren't done with 93. I'm ready to move on to E85
Old Apr 13, 2015 | 05:07 PM
  #102
NICOSLOW's Avatar
Glad to hear you got the bugs worked out, car looks great.
Old Apr 14, 2015 | 12:35 PM
  #103
WWGSR's Avatar
Great job
Old May 28, 2015 | 08:12 PM
  #104
tscompusa's Avatar
Heres a update for you guys wanting to know more about Nick's progress. Last night we did final touches, but i know theres more in the car yet.
I know a EF4 can run more then 32psi out of the top end, so I sent Nick on a chase again to find some bugs. I suspect something funky with the wastegate actuator.
90% WGDC and we only got 32psi uptop. I also asked him to leak test the car again also just for reassurance.
Heres what we got now which is basically done, but if i can get the boost up, the car should make more power then this. quite a bit more.
Old Jun 16, 2015 | 10:49 AM
  #105
STLEVOIX's Avatar
So he is making 525HP 449tq on a built block with a MAP EF4 @34lbs of boost? That seems awfully low. Does this not have any timing in it?
