Dynamic's Chariot
What does that SD kit you pictured plug into? Where did you buy it?
The SD harness pictured is from Spoolinup. It plugs into the stock MAF connector and then into your GM IAT.
I'm actually glad you brought this up because now that I look at it I think Spoolinup sent me the wrong one. It looks like I have the "Mrfred Harness" but I actually wanted the standard SD harness. (the mrfred harness has a 3rd connector for active baro support through the use of the stock map sensor.. something I probably won't be needing)
Here is their site. Prices and quality can't be beat. www.spoolinup.com
Ah no way that's awesome! Thanks for the kind words dude, much appreciated.
Ok good to know
Ok good to know
I dont think you need any of that, I am running SD and all I have is a Omni 4 bar map sensor and I pull the fuel temps instead of the IAT. Fuel temps are widely used on evom, best part is you dont need any external sensors to read it. The evo has it oem.
I might do that. I was reading that in another thread also
