Custom FF setup - 6266 - stock block
Old Mar 14, 2014 | 12:05 AM
Evo_AK's Avatar
Veteran: Air Force
Originally Posted by Czarcasm
Decided not to run AN lines for the radiator because of the bottom engine mount. About 1" of room between the fitting and the mount, either a 90 or go back to regular aluminum pipe, which I can make. Only bad part now is I gotta chop off the fittings and pray all the shavings get flushed out afterwards.
If you really wanted to run AN fittings, STM's Koyo radiator has it's fittings centered, so you don't run into that problem. That's what I'm going to be running.
Old Mar 14, 2014 | 08:42 AM
Czarcasm's Avatar
Thanks for the input. I rather weld this one instead of going thru the hassle of reselling it and getting the rad from STM
Old Mar 14, 2014 | 04:18 PM
Czarcasm's Avatar
Oil return line is in. Next up is the fuel line kit and mount the regulator. After that the radiator
Old Mar 16, 2014 | 04:11 PM
Czarcasm's Avatar
Got the fuel setup out of the way today. Refreshed the injectors with new O rings, made a small bracket for the FPR and mounted it behind the IM.
Old Mar 17, 2014 | 05:06 PM
mitsubeastlee's Avatar
Looking great I like the fpr bracket!
I think I lost my oem oil pan bolts for oil return line...what size are they?
Old Mar 18, 2014 | 09:33 AM
DDGDSM's Avatar
Pretty close to my setup and girection im going on mine with my 35R setup on stock block. You went FF whereas i didnt. Few changes but almost the same setup. GL on yours im currently in the tuning stages of mine.
Old Mar 18, 2014 | 10:42 AM
06MREvo's Avatar
I like the way you mounted the FPR as well, looking good sir!
Old Mar 18, 2014 | 03:02 PM
alex_s817's Avatar
that looks like a buschur fluidyne rad? if so, just wanted to mention that they use -10an hose on there purposely so that they can slow the coolant speed down. This allows for more heat to be extracted from the coolant on each pass. I think it would be more effective for you to move the -an fitting over rather than using standard 35mm hose ends. just my two cents
Old Mar 18, 2014 | 04:02 PM
Czarcasm's Avatar
You talking about the OEM flange and bolts or aftermarket?
Please post your dyno sheet #s. Im interested with the outcome. Also your mod list
Thank you sir
Got any input on driving this on the street? The 10an fittings and hoses seem really small for coolant to pass thru, but you mentioned "after each pass" so its a drag strip only radiator? And yea its the fluidyne from buschur
Old Mar 18, 2014 | 04:06 PM
DDGDSM's Avatar
Thank you sir
If you look at my build thread/or my signature has most of them. The mild to wild TB Evo 8 thread.
Old Mar 18, 2014 | 04:27 PM
Czarcasm's Avatar
I had the mobile version on, sorry about that. I read through your build thread the other night, by far one of the cleanest. Keep up the good work
Old Mar 18, 2014 | 04:37 PM
ctfpevoVIII's Avatar
Your car looks awesome and very nice build. In your pic of your car next to your buddy's are those your 10" wide wheels ?If so the stance looks perfect , I was expecting the wheels to really stick out further. GLW your car man.
Old Mar 18, 2014 | 05:05 PM
Czarcasm's Avatar
Thanks man. It took alot to make them fit properly, evodave fender mod, rolling the fenders all around, 18mm spacers and extended studs in the front, removed the inner fender liners and its still rubs when doing a full turn
Old Mar 19, 2014 | 07:05 AM
alex_s817's Avatar
sorry by after "each pass" I meant each time "X" volume of coolant runs through the radiator. Basically it just slows it down so that it has more time for the heat to be pulled out. Fluidyne and Buschur are both very good at what they do, so I dont doubt their methods, just wanted to make sure that you knew thats why they used the smaller fittings. When I first saw it, I thought it was ridiculous too lol. David said that his car with this radiator has a hard time coming up to operating temp, but hes running an electric water pump and no thermostat as well. Are you planning on running AC with this setup? I think if you just cut/plug that fitting and put a -10an over a few inches so that it clears the mount you should be fine.
Old Mar 19, 2014 | 05:10 PM
Czarcasm's Avatar
Oh ok I see what you mean, basically a bottle neck. I dont question their work but I do want some answers as to why they did it, you explained it well. I wont be running AC but I will have a flexalite fan on it.
