PIRANA's Evo9 MR Rebuild Update!
Old Apr 23, 2014 | 01:02 PM
Pirana's Avatar
Originally Posted by evoforstevo
God that hardware.........so beautiful
Got tired of looking at rusted bolts!!!
Originally Posted by mkreiner
Really exciting to see someone who takes the time and effort to do something the right way. I'm sure it will pay dividends in longevity. Looks great!
Thank you!!!! The good stuff still coming...too many pics!
Originally Posted by FLOW1
Damn you're getting everything brand spanking new or rebuilt like new haha awesome...you going to have the same power or abit more power now with everything refreshed?
Better safe than sorry. The refresh stuff wasnt as expensive as getting new and way quicker. Im hoping for a little more.
Old Apr 23, 2014 | 01:44 PM
Sharkbite2000's Avatar
Holly smoke's batman!!! You went in!!!
Old Apr 23, 2014 | 01:57 PM
Pirana's Avatar
all the way!!! hehehe
Old Apr 23, 2014 | 04:38 PM
Pirana's Avatar
The fun started...the block came back from the machine shop. I decided to give it a little paint refresh
Assembly of the new oil pump.
Start block assembly. Also new water pump....why not?
New oil filer housing.
Freshly reassembled block with new copper O-rings.
ARP studs and OEM head gasket...never had any problems with the OEM one.
Thats my fat *** installing the head. Also notice the AN fitting on the side of the block for venting.
Torquing the head.
Lube lube!
Kiggly Racing
Old Apr 23, 2014 | 06:01 PM
notw_evo9's Avatar
WOW!.....just wow! thats an awesome build lol
Old Apr 23, 2014 | 06:11 PM
mitsubeastlee's Avatar
holy smokes.........you really went in none of that tip ****! keep em cuming
Old Apr 23, 2014 | 06:34 PM
Pirana's Avatar
New lifters...dont know why...but they were inexpensive.
Bleeding the lifters to make them ready for installation.
Tomei 280 cams and Supertech valve springs and retainers
Upside down to bolt on the "scraper" and oil pan.
Even torqued the oil pan bolts.
Looking nice!!!
All new timing components including gears, tensioner, pullies, all!!! See if you spot the gem!
HKS cam gear with ARP bolt and timing belt. AMS tensioner tool.
Fluidampr pulley with ARP bolt.
Old Apr 23, 2014 | 06:45 PM
Pirana's Avatar
ARP studs for the exhaust manifold.
Mocking up the AMS manifold. here you can also see I sent all the mounting brackets to get ceramic coated.
AMS manifold collector shot
ARP stainless steel bolts holding the turbo housing.
More ARP stainless hardware for the downpipe.
EATON metric AN adapters for the oil feed and return line.
ARP studs holding the manifold. That last M12 was a *****!!
Old Apr 23, 2014 | 07:54 PM
Pirana's Avatar
Here you can see better the P/S & A/C brackets ceramic coated.
The thermostat housing and cam sensor housings were also coated.
Wastegate and dump tube mounted...also with ARP bolts.
Thats also a brand new lower timing belt cover...they look nice when new!
Ready to mount the AMS F1 intake with Boomba 75mm throttle body.
thats one fat intake!!!
ARP studs for the intake...I hope I dont have to remove this while in the engine bay!!!
PTE 1200cc injectors installed with new seals.
Ready for the AMS fuel rail.
Now this is a cool view from the bottom, too bad this cant be seen. Here you see the AMS intake support bracket and the Legris stainless steel quick disconnects for the vaccum lines.
New Knock sensor.
Installing the reconditioned Quarter Master 8-leg twin-disc clutch.
Hmm, can someone spot whats missing????
Old Apr 23, 2014 | 08:05 PM
detroit pistins's Avatar
Everything is nice and clean. Great pics too!
Old Apr 23, 2014 | 08:45 PM
Pirana's Avatar
thanks, some pics are with a Canon the others with my phone!
Old Apr 24, 2014 | 09:37 AM
STLEVOIX's Avatar
Looks awesome! Been a fan of this Evo for a long time. DO you happen to have the part number on those EATON metric AN adapters for the oil feed and return line? Thanks!
Old Apr 24, 2014 | 09:38 AM
needmoreboost!!'s Avatar
Bro is this recent or just the previous updates from your other thread? Cuz if its recent you work fast bro lol
Old Apr 24, 2014 | 10:14 AM
siikEvo92's Avatar
I need all those new bolts in my life..
Old Apr 24, 2014 | 10:18 AM
InfernoEagle's Avatar
This is an absolutely awesome rebuild! Your attention to detail makes it even better haha. I wish to do the same someday
