MIL.SPEC lightweight 2.3 MR build
Old Jan 11, 2024, 04:35 PM
  #271
MIL.SPEC Erik's Avatar
UPDATE:
So, um, like building a car is like working through therapy (or so I'm going to guess). LOT OF ISSUES.
First off, I can't believe the last post I have in this thread is over 4 years old.
Second, **** HAPPENS, MAN. Like COVID upending your life. I live in freaking Oklahoma, now.
Third, about 2 years ago (April 2022), everything finally got installed and put together. I happend to be in LA and with the car at KT Motoring when it got cranked over. That was exciting. THEN...
At some point (awhile later) a cam gear slipped and car bent a valve. Head was pulled. Valve was fixed. Car was put back together. THEN...
Car was restarted and made a funny noise. Car was turned off, engine diagnosed, and weird wear showed up on the thrust bearings. Enter NEW CRANKSHAFT.
Then, I got a text this week and was sent this...(video attached).
So, she's alive. EIGHT years after I started this thread. And over 1.5 years since car was first started up. So, I'll say two things:
1) Life is weird.
2) I'm excited to get her back and tuned, and then getting a Speed Density FlexFuel E85 tune from John Bradley.
I'm actually tempted to sell the FP Red and get the Art Gennari 57mm turbo, since it fits the Red turbine housing (It's essentially a Zephyr that can attach to an MHI housing). Push an extra 25 - 40 whp and be done with it without being tempted by the FP Black.
Also, since I don't have to deal with CARB anymore (no smog in Oklahoma), I am pretty sure I'll throw on a Magnus intake manifold.
Think that's it. Thanks to everyone that has been a part of the rollercoaster of a thread lol
File Type: mov
The following 2 users liked this post by MIL.SPEC Erik:
codgi (Jan 26, 2024), rustykan (Jan 12, 2024)
Old Jan 11, 2024, 04:51 PM
  #272
CurseDSM's Avatar
Wow 8 years and she finally lives. That is exciting and congrats. Just think all that hard work, the blood, sweat and tears and all the money that was spent and now you have to think to yourself ah **** now everything is outdated time to rebuild with current stuff lol.
MIL.SPEC Erik (Jan 11, 2024)
Old Jan 11, 2024, 07:35 PM
  #273
Thanks.
Yeah, so many new parts lol. Yesterday I was like, "There's a 57mm MHI bolt on that is 65#/min vs 61#/min HTZ Red????" I NEED lolol
I feel like there should be a support group for car builds. Obviously mine is probably WAY longer than most, but so much can happen. In hindsight, I may have opted for a much simpler build than what I did (not that I regret anything).
Like, I'm not worried about the MAF sensor and other little things with the car right now. Just want it running (which it is) and tuned (which it is not yet) so I can get the break in miles in and worry about 4" intake, speed density, etc, etc.
I do hope that it revs quick with all the lightening/friction mods I've done, but time will tell. Running is better than perfect lol
Old Jan 11, 2024, 08:52 PM
  #274
RallySport9's Avatar
Yes..and no. If I could pick between a ct9a built with the newest parts vs one built with "old new" parts. Id pick the old one. Cars just seem to do better when modified with parts made and designed for that era. period correct isn't just a term for aesthetics. Plus with the exception of engine management systems I don't really see the major advance in engine/turbocharger engineering in the last 10-15 years things sort of hit a peak back then and just got more efficient since then is all.
Old Jan 12, 2024, 01:38 AM
  #275
CurseDSM's Avatar
I hate to disagee with you on that but I am going to lol. I mean there are better quality, better material parts like rods and pistons that make a difference in the way cars will react to them. Hell even clutch stuff has come a long way and those are major parts of the car. I would never ever, ever buy ACT anything 10 years ago but now with them changing a bunch of stuff and making their clutches better I now have one in the car and I push it a ton and for the most part it holds. I mean it handles 875 or something like that tq, but to the flywheel where I am making that at the wheels and does it slip? yeah it does but only for a split second and even with organic discs. That is the kinda stuff I am talking about. I would never do that with any organic clutch 10 years ago.
The following 2 users liked this post by CurseDSM:
codgi (Jan 26, 2024), schuhie (Jan 12, 2024)
Old Jan 15, 2024, 12:25 PM
  #276
thepoint4life23's Avatar
Any idea what you think cased the wear on the thrust bearings?
Old Jan 15, 2024, 04:09 PM
  #277
Well, I bought it used on the forums (OEM 4G64 crank) and had a bunch of **** done to it. (meaning a bunch of different hands touched it).
Sent it to some super-flakey crankshaft shop in SoCal to make sure it was true and balanced, etc. Then, I sent it to FFWD Motorsports to have them machine the counterweights and lighten it and balanced (their Vader crank..BTW I just checked and they don't offer the service anymore). I then had a top level machine shop check the work, and they said it needed to be balanced more.
Long story short, I don't know.
UPDATE: The leak they were chasing in the video I attached ended up being the oil pump was leaking from the case (shop said that was a new one). It was a brand new pump, BTW. Swapped with new pump and leak went away.
Also, seals on the FP Red seemed to be bad (smoke in the exhaust), so turbo is being sent back to FP. (Shop swapped in Evo 9 turbo and smoke went away).
I swear, either something is seriously wrong somewhere or I've had an inordinate amount of gremlins to deal with lol
Oh well, at this point, things seem to be good. Once we get the turbo back from FP, engine will get broken in.
Old Jan 15, 2024, 04:55 PM
  #278
After thinking about it, I think I'm just going to keep the FP Red. I don't need to go down another parts rabbit hole, especially since those new issues crept up.
In my car, the rods a billet and the pistons are billet. Hopefully that's "good enough." Aby had them design the piston tops according to his spec with proper dish.
At this point, I just want to drive the damn thing lol
Old Jan 16, 2024, 07:18 AM
  #279
Sorry was just asking, wasn't sure if you thought when you jump timing it hurt the crank.
Also I get sticking with your turbo and not wanting to go down a rabbit hole. I have an FP black and I could make more power with it but I just don't really feel like doing a double pump and doing all that comes with it.
Old Jan 17, 2024, 09:43 AM
  #280
RazorLab's Avatar
Received 1,043 Likes on 762 Posts
Wow, I thought you were long gone by now.
Old Jan 18, 2024, 01:50 PM
  #281
CurseDSM's Avatar
I totally get it. You put a lot of money into something like that its hard to go and spend more on the same things just newer. Thankfully your had custom parts and those will be fine. I mean the red should be ok but I am just not a fan of FP stuff lol.
Old Jan 22, 2024, 11:10 AM
  #282
M4Lki3r's Avatar
Glad to see you're still doing ok and the car is alive!
I was very surprised when an update to the thread hit my inbox. Keep up the work!
Robertv34
12
Jul 5, 2012 10:02 AM
3dman1
Apr 30, 2012 08:12 PM
LI Pinky
31
Sep 1, 2011 10:11 AM
David Buschur
287
Jun 16, 2010 02:36 PM
20gmr
21
Mar 17, 2009 12:48 AM
Quick Reply: MIL.SPEC lightweight 2.3 MR build
