Evo IX 2.3 Liter Build FP Black Build
Old Dec 13, 2017 | 11:41 AM
  #496
Pal215's Avatar
Last night we finished the 91 map and began tuning on E85. Prior to this I pulled the spark plugs to give them a check, they look fantastic! I also did a compression test and all the numbers are within 1 psi of each other.
Earlier this week, I replaced the IACV. It turns out I didn't need to, but hey after 115,000 miles I figured it couldn't hurt as I can keep the old one as a spare. I found out that the o-ring that surrounds the IACV was missing from the IACV plastic outer ring. Not pointing any fingers, but MAP was the last company to service my throttle body when I sent it in for porting. I have no malicious intentions or proof, so this is that and the problem has now been addressed.
The compute stick is working well thus far for flashing and logging. The trick is to use the windows 10 scaling function to make the text and icons larger, otherwise everything is too small to see with such high resolution and small screen.
More updates to come!
Old Dec 14, 2017 | 03:30 PM
  #497
heel2toe's Avatar
Plugs look consistent and hard to beat the compression test results! Curious as I havent look inside a TB with the IAC out in a while but are those leftover pieces of o ring or is that a shadow from shall we call it low spots inside?
Old Dec 15, 2017 | 07:51 AM
  #498
LetsGetThisDone's Avatar
LOL at MAP.
Plugs look perfect!
Old Dec 15, 2017 | 01:07 PM
  #499
Kevin Troy's Avatar
They have become sloppy
Old Dec 15, 2017 | 03:22 PM
  #500
Pal215's Avatar
I thought those were left over pieces of O-ring as well. They are actually two metal circles (left and right sides) that are engraved into the IACV housing. I don't know their purpose, but i'm sure it has something to do with controlling the air flow in that cavity.
LOL at MAP.
Plugs look perfect!
Thanks !
Looks like they spend more time marketing these days than developing their QC process.
Old Dec 21, 2017 | 05:43 AM
  #501
evoforstevo's Avatar
What a read. Can't wait to see where this goes.
Old Dec 29, 2017 | 08:25 PM
  #502
silverflyer's Avatar
What model flip up head unit is that? It looks great!
I use this as a logging trigger for EvoScan.
Amazon Amazon
Old Dec 31, 2017 | 11:40 AM
  #503
Pal215's Avatar
https://www.amazon.com/gp/product/B01LN3Z5SO/
Thanks! It's a Power Acoustik PDN-726B. The sound quality and picture quality is acceptable, but i'm using an external amp (Crunch 1800 watt) and Alpine type R's all around.
That's a neat trick using that trigger pen! It would make it safer to log on the road.
Old Mar 20, 2018 | 09:40 AM
  #504
Pal215's Avatar
Quick update guys! Look at how yellow and sh!tty my headlights are right now. I've decided to re-clear my headlights and I'm using a very simple 3 step method. Just cleaning, wet sanding with 800 grit , masking, and clear. No plastic adhesion promoter and no sanding with 1000 to 2500. This is just what I see working after doing a bit of research. I've decided to remove the front bumper, but leave the headlights on the car so that I don't risk screwing up the factory headlight alignment, breaking any brittle wires, or giving myself more problems than I needed to fix.
Yellow driver side
Yellow passenger side
Finished wet sanding driver side
Once I apply the 2k clear, they will gloss up and look factory again.
Also I am happy to report that my engine does not burn oil anymore. I can't even measure oil loss on the dipstick, it's all still there from 2000 miles ago haha *knocks on wood*
Old Mar 20, 2018 | 08:36 PM
  #505
Crazy how well they work when they're built right
Old Mar 24, 2018 | 09:29 PM
  #506
Pal215's Avatar
Yeah, ain't it something ? All it took was a complete self *** woopin
Old Mar 24, 2018 | 09:33 PM
  #507
Pal215's Avatar
Headlights are done and they came out brilliant! Such a stupid easy process, but it involves wasting most of the can of 2k clear. Once the catalyst is activated, you have to use the can within 48 hours, better in 24. They look great now, but I can take it a step further and give them a nice polish in about a month to cut down on any orange peel. I applied two coats of the clear after wiping the headlights down with rubbing alcohol three times.
There is something majestic about saving $2500.00.....
Old Mar 25, 2018 | 02:43 PM
  #508
Damn they look good. Give them 30 days to cure, give them a good polish then ceramic coat them.
Old Mar 26, 2018 | 08:53 AM
  #509
Pal215's Avatar
Damn they look good. Give them 30 days to clear, give them a good polish then ceramic coat them.
Thanks man! Yeah, I should probably do that. They would look closer to glass headlights after that XD
Old Mar 26, 2018 | 09:31 AM
  #510
And the coating will keep them fresh.
