Group Evo IX Engine Build
Old Apr 25, 2018 | 05:20 PM
2006EvoIXer's Avatar
I just realized that once I swap out my original motor with this build, I really want that motor built to perfection because I want matching VIN. So this motor is more of a temporary use so I can take my time building my factory block.
So, this build should be "best value" build where I'll include any upgrades that isn't too expensive and save the bells and whistles for the second build (my original block).
Old Apr 25, 2018 | 05:56 PM
LetsGetThisDone's Avatar
Blocks aren't VIN'ed.
Old Apr 25, 2018 | 06:02 PM
I saw this on ebay. Guess I'll check my car when I get home. Maybe this is JDM?
Old Apr 25, 2018 | 06:39 PM
Biggiesacks's Avatar
maybe he just means the block serial # matches the chassis. This is kind of a thing when it comes to classic cars, not so sure how much it would apply to the evo market, but it does make sense to want to keep them together if possible.
Old Apr 25, 2018 | 07:06 PM
Just checked. My block does have matching VIN.
Old Apr 25, 2018 | 08:06 PM
First time I've seen that. Looks like a sticker. Put it on the new motor lol
Old Apr 25, 2018 | 08:15 PM
I was just wondering how hard would it be to remove and glue on another block
Old Apr 25, 2018 | 08:27 PM
Ayoustin's Avatar
Yup, block does have matching VIN, as does the trans IIRC. I noticed it when I pulled my engine the first time. Still matching for this guy
But yea if you're just doing a "hold you over" build then just keep the factory crank and throw some cheap (Eagle, Manley, etc.) H beams at it with some equally cheap pistons. That's the route I went (Manley standard H beams and a set of their pistons) and the engine hasn't skipped a beat making 400whp/400wtq@3700ish on a 3B turbo.
Old Apr 25, 2018 | 08:52 PM
Yes, hold me over, but the machine work still costs some. I'll look for value upgrades since I could look for another evo 9 with blown engine and drop it in that.
Old Apr 25, 2018 | 09:04 PM
Ayoustin's Avatar
Get the block checked out, you may not need as much machine work done as you think. I haven't touched my block, my bores were immaculate so I just threw std sized pistons in. The main bores and deck were good as well so there wasn't any need for any machine work on my block. Just refresh the cyl walls with a ball hone to get the new rings to seal nicely and you're off to the races.
Old Apr 25, 2018 | 09:46 PM
I bought bare evo 9 block. So I'll need crank, pistons, and rods anyway.
Old Apr 26, 2018 | 10:27 AM
Just bought a FP MHI Black and a FP MHI Red.
Old Apr 26, 2018 | 11:43 AM
You'll want better rods and pistons than bargain basement stuff to go with a black.
Old Apr 26, 2018 | 12:06 PM
Thanks.
Old Apr 26, 2018 | 12:13 PM
Make sure you get the wrist pin upgrade for those pistons. Which, like I said, will then put them in line with pricing for custom Wiseco's from ER. You can also get a better price on the crank.
