FS: EVO 8 Engine, transmission, turbo, exhaust, act clutch, flywheel, radiator etc.
Selling a lot of drivetrain parts from my 2005 EVO 8. Car has 84k miles on it. I'm looking to start over with a new build later on, trying to gather up some cash in the meantime.
I will get some better pictures up this weekend when I start taking the car apart. Trying to get some interest started.
05 EVO 8 ACD Transfer case - In great condition. $1000
ACT XTSS clutch - street disc version, about 15-20k miles on it, lots of life left, holds great, drives like new. Includes pressure plate and clutch disc. Pics below. Surface of pressure plate is in good condition. A very small ring of surface rust spots around the very outer edge that doesn't affect anything. This just came off of the car which was in great running condition. Car has been sitting for about 3-4 months but the clutch was just removed now along with the transmission. $350 obo
ACT XACT Flywheel prolite ~10lb version. In good condition. Like the clutch, this just came off a running car and worked perfectly. There is a small spot of surface rust around an inch or two in length that I couldn't clean off with brake cleaner. You can see in one pic where I showed it in between a couple pieces of paper. I think it would come off with some very fine sandpaper but I didn't want to mess with it myself. It's probably fine to run as is, it was on the car until now and never caused issues when I drove on it. $200
A/C system - condenser, compressor, lines, etc. If somebody needs all of this stuff because they ditch their a/c, I'm thinking about taking mine out and selling it whole. Possibly part out. Make offers.
sold stuff
Stock 05 EVO 8 engine 84k miles. Very good condition. Recently tested over 150 compression across the board. Never been opened up. No leaks. Longblock. No accessories included. No fuel injectors. Will include manifolds, no throttle body, no turbo. Will sell turbo with if interested and I still have it for sale. Engine will need timing belt and water pump replaced as it is due for that maintenance. Would prefer pickup or meet somebody a short distance. May consider shipping. SOLD
Stock evo 8 turbo 10.5. Some mild porting to match gaskets. Very little side to side play, no in and out. Great shape. Will include oil/coolant lines. I have the stock O2 housing on a shelf I can throw in for extra shipping. The o2 sensor is seized inside the housing. Was using Megan o2 housing on the car. SOLD
Buschur Racing 3" downpipe. Still in good condition, o2 bung for wideband already in place. SOLD
Megan Racing o2 housing. SOLD
Walbro 255 fuel pump SOLD
EVO 8 Mishimoto radiator. Used for about 30k miles. In good condition, some bent fins on the firewall facing side, nothing affecting performance. One of the two top bolt holes to mount the stock radiator fan has a bolt broken off in it. I ran my fan fine with just one bolt on top. Can probably be tapped/drilled out to get the old bolt out. Also a non-issue if you are going to run an aftermarket fan and not use the stock mounting holes. SOLD
evo 8 5-speed transmission 84k miles. In excellent condition, absolutely no grinds.
Stock EVO 8 radiator fan and control module - SOLD
EVO 8 Tanabe Hyper Medallion cat back exhaust. 3". Sounds awesome, not loud and drony but loud enough when you are getting into it, not too many of these around. In good condition, no rust, some of the finish has peeled off the muffler but the tip is all stainless and still looks pretty good(only part you see when it's on the car). SOLD
sold stuff
