Rattling on Deceleration/Coasting
Old Aug 21, 2024 | 08:20 PM
OctBlueEvoX08's Avatar
Has any one figured out what causes a rattling noise when decelerating/ coasting? I’ve looked everywhere in the engine bay but couldn’t find anything.
sound will go away after the clutch is pressed down.
Old Aug 22, 2024 | 03:54 AM
varv's Avatar
Hi. Check out my post, it sounds similar.
https://www.evolutionm.net/forums/ev...ing-noise.html
Old Aug 22, 2024 | 11:56 PM
Thanks! I appreciate it. I’m looking for the ring and pinion to replace it.
do you happen to know of the Evo 9 fits the Evo x T Case?
Old Aug 23, 2024 | 10:45 AM
varv's Avatar
As far as I know ring and pinion are different between evo 4-6, 7-9 and 10. If you are referring to swapping your transfer case with one from evo X then I think it's also not compatible taking into account that gearbox of X is different than 9 as stated here:
https://www.evolutionm.net/forums/ev...evo-8-9-a.html
Old Aug 23, 2024 | 11:56 AM
I have an Evo x. I tried looking for the gearset but I can’t find even the part number but I was looking at picture of an evo 9 gearset and they look identical to the Evo x.
Old Aug 23, 2024 | 02:40 PM
ViciousLSD's Avatar
try contacting sheptrans.com or maybe just ship the diff to them
have you opened the cover and inspected for wear? that could have large metal pieces in there waiting to get between the teeth and make more damage
Old Mar 21, 2026 | 05:58 PM
Limevo's Avatar
https://youtu.be/hzu7sDa1n4Q
Sorry for a little bit of a dig, but did you resolve this? Just developed seemingly identical symptoms after a track day
Thanks in advance!
Old Mar 21, 2026 | 06:02 PM
Thanks in advance!
yes sir, it was the transfer case. The ring and pinion gears were destroyed. Drain your transfer case fluid and check the fluid.
Old Mar 21, 2026 | 06:32 PM
Limevo's Avatar
Ah, guess that's the new plan for my Sunday . Thanks for the mega quick response, will let you know what I discover
Old Mar 21, 2026 | 07:09 PM
have fun removing it. I removed it on my back alone and it was not fun. There is a video on YouTube that shows how to remove it if you want to give it a go.
Old Mar 26, 2026 | 11:39 AM
ViciousLSD's Avatar
on the evo ix, I seperate it if it needed service. tail section, cover, LSD and the rest and assemble it in the car. its tricky to make the splines align but atleast its not heavy. i also remove just the cover if needing a new axle seal. I'm not sure how it is with the evox
i just reinstalled it (as one unit) last night after a clutch job and my joints are sore. had a good sleep tho
Old Mar 31, 2026 | 08:47 AM
on the Evo x you can’t leave the section behind because there isn’t enough room. When removing it, if I remember correctly, you have to twist it to drop it down.
RalliRalli
Mar 22, 2015 12:59 PM
benniboi08
13
Jun 22, 2009 11:38 AM
Jehuty
Lancer Troubleshooting
Aug 16, 2008 12:03 PM
HREVO
Nov 10, 2004 08:32 AM
ToFast4U
Apr 26, 2004 03:02 PM
