Site Feedback / Suggestions If you have any suggestions or want to see something voice your opinion in here.
Help! I cannot load the evolutionm website from my home computer!!?
Old Dec 1, 2006 | 09:31 AM
Jakeg97's Avatar
Originally Posted by rcheung
It may be a routing issue. Go to this website http://www.hidemyass.com/ and see if you can reach if from there. This is a free website proxy so it would route a different way.
I am able to load and log in through the proxy , but I cannot respond to any pms, cannot quote text in a response to a thread (as I doing now), nor be able to create a new thread.
My question is- Since I am able to log on/view this website by using a proxy from my home computer, (which in my understanding hides/cloaks my identity, or my computer's ip address) , could that possibly mean that evom has banned my home computer's access? or is it that my route to evom simply doenst work anymore from home, and if so what might have caused this sudden block on only one specific website?
thanks for all the help so far
Old Dec 3, 2006 | 01:45 AM
twardnw's Avatar
Code:
C:\\Documents and Settings\\tward>tracert evolutionm.net
Tracing route to evolutionm.net [216.193.220.4]
over a maximum of 30 hops:
  1     *        *        *     Request timed out.
  2     8 ms     6 ms     7 ms  GE-1-10-ur03.beaverton.o
8.87.218.249]
  3     7 ms     *        7 ms  10g-9-2-ar01.beaverton.o
8.87.216.29]
  4    15 ms    19 ms    16 ms  12.118.177.49
  5    17 ms    16 ms    15 ms  gr1-p340.st6wa.ip.att.ne
  6    16 ms    16 ms    16 ms  tbr1-p012501.st6wa.ip.at
  7    22 ms    18 ms    21 ms  12.127.6.57
  8    17 ms    16 ms    16 ms  br1-a350s5.attga.ip.att.
  9    45 ms    67 ms    46 ms  ge1-1-10G.ar4.LAX1.gblx.
 10    47 ms    42 ms    42 ms  64.215.30.206
 11    42 ms    44 ms    43 ms  72.34.41.1
 12     *        *        *     Request timed out.
 13     *        *        *     Request timed out.
 14     *        *     ^C
just keeps timing out from there
Originally Posted by whois query for 72.34.41.1
WHOIS results for 72.34.41.1
Generated by www.DNSstuff.com
NOTE: More information appears to be available at IHNET-ARIN.
OrgName: IH Networks
OrgID: IHNET
Address: 16060 Ventura Blvd
Address: Suite 105
City: Encino
StateProv: CA
PostalCode: 91436
Country: US
NetRange: 72.34.32.0 - 72.34.63.255
CIDR: 72.34.32.0/19
NetName: IHNET-PI-1
NetHandle: NET-72-34-32-0-1
Parent: NET-72-0-0-0-0
NetType: Direct Allocation
NameServer: NS6.ELINUXSERVERS.COM
NameServer: NS7.ELINUXSERVERS.COM
NameServer: NS8.ELINUXSERVERS.COM
NameServer: NS9.ELINUXSERVERS.COM
Comment:
RegDate: 2005-02-09
Updated: 2006-08-14
OrgTechHandle: IHNET-ARIN
OrgTechName: IH Networks
OrgTechPhone: +1-800-285-2850
OrgTechEmail: *****@ihnetworks.net
# ARIN WHOIS database, last updated 2006-12-02 19:10
# Enter ? for additional hints on searching ARIN\'s WHOIS database.
what\'s our relationship to this IP?
or can someone not on a comcast network run a traceroute and post the results here?
Old Dec 3, 2006 | 08:31 AM
Jakeg97's Avatar
72.34.41.1 timed out for me as well
what gives???
C:\\DOCUME~1\\JAKE>tracert evolutionm.net
1 15 ms 13 ms 7 ms 10.109.240.1
2 7 ms 7 ms 12 ms fas1-2.rochnystf-rtr01.nyroc.rr.com [24.93.2.194
3 9 ms 10 ms 9 ms srp7-0.rochnymth-rtr03.nyroc.rr.com [24.93.3.119
4 8 ms 8 ms 9 ms rdc-24-93-4-249.nyroc.rr.com [24.93.4.249]
5 18 ms 12 ms 11 ms son0-0-2.syrcnyspp-rtr06.nyroc.rr.com [24.92.224
.173]
6 18 ms 29 ms 25 ms so-2-1-0-0.gar1.Philadelphia1.Level3.net [4.78.1
48.5]
7 * 22 ms * ge-7-0-0.mp1.Philadelphia1.Level3.net [209.247.9
.229]
8 26 ms 87 ms 38 ms ae-1-100.ebr2.NewYork1.Level3.net [4.69.132.26]
9 85 ms 85 ms * ae-11-53.car1.LosAngeles1.Level3.net [4.68.102.7
6]
10 98 ms * * ge1-0.cr01.lax01.mzima.net [63.209.80.78]
11 98 ms 62 ms 98 ms xe1-0.cr01.lax02.mzima.net [64.235.224.182]
12 102 ms * 97 ms ge1-ihnetworks.cust.lax02.mzima.net [72.37.172.6
2]
13 * 99 ms 106 ms 72.34.41.1
14 * * * Request timed out.
15 102 ms * 101 ms ae-11-51.car1.LosAngeles1.Level3.net [4.68.102.1
2]
16 115 ms * 107 ms ge1-0.cr01.lax01.mzima.net [63.209.80.78]
17 * * 94 ms xe1-0.cr01.lax02.mzima.net [64.235.224.182]
18 * 132 ms 121 ms ge1-ihnetworks.cust.lax02.mzima.net [72.37.172.6
2]
19 * 101 ms * 72.34.41.1
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
btw - I cant even do a simple search on here with a proxy log on! #^&*!*%@#!
Old Dec 3, 2006 | 12:42 PM
Speedlimit's Avatar
Admin Emeritus
Please PM me your home IP address. I realize it is not static, but I will check to ensure your IP is not included in a block range. Thanks.
Old Dec 4, 2006 | 02:31 PM
Jakeg97's Avatar
pm sent
thanks for checking
Old Dec 7, 2006 | 06:48 PM
timzcat's Avatar
Did you get this resolved?
This happened to me previously.
Do you have cable? What router/gateway are you using?
What happens sometimes is home router devices can get stuck on the WAN address when Comcast has changed your address the router doesn't pick it up and you are stuck on ytour old address. It's weird because it keeps DHCPing the old address even though it is not valid. This happened to me on an SMC router.
Turn off your router completely and unplug your WAN cable from the modem and plug it into anything that will dhcp it an address. For example, plug your WAN port into your LAN port of your router and turn it on. View your routers page to ensure it got an address on the WAN port that matches your LAN. Then turn the router off and unplug your modem. Reconnect the router WAN to the Modem and turn the router on and plug the modem back in.
When I experienced this issue I had no problems with anything on the internet except this site. It just so happens that this is site is in a different route plan then say google for your ISP.
Old Dec 7, 2006 | 06:51 PM
Spec'd's Avatar
Looks like a possible spybot redirect browser hyjack.
http://security.ittoolbox.com/groups...l/oingo-937410
Old Dec 7, 2006 | 07:13 PM
Speedlimit's Avatar
Admin Emeritus
There does not appear to be any overlap with IP blocks from this side. I hope you find the cause.
Old Dec 7, 2006 | 08:24 PM
twardnw's Avatar
I\'m going to call comcast now and ask them to force a DHCP release/renew of my address, they should be able to. ISP I worked for in the past would do that. Maybe that will help.
Old Dec 7, 2006 | 08:42 PM
twardnw's Avatar
Welp, they won\'t do that for me. But he did offer to sell me a static IP hmmm, I\'m running out of ideas, and browsing via proxy sucks
Old Dec 11, 2006 | 02:09 PM
Jakeg97's Avatar
I still was not able to locate the cause , but the update to this website has proven to be the fix. I now can log on without a proxy!!
Thanks again for all the help
Old Dec 11, 2006 | 09:28 PM
twardnw's Avatar
as can I
Acuality
Apr 11, 2016 03:06 PM
flippymcbean
Sep 15, 2014 03:46 PM
blknblubkrdude
Apr 29, 2012 02:57 PM
hearnoevo
Sep 14, 2010 08:15 AM
Tanner65
Jul 12, 2004 07:40 PM
