South Region Includes AR, LA, MS, NM, OK, TX, NE, KS.
Ft Hood Evo Check-in
Old Apr 27, 2009 | 02:51 PM
  #1111
Levar's Avatar
Veteran: Army
Is this what you are referring to?
https://secure.buschurracing.com/cat...89e129eae71198
Old Apr 27, 2009 | 03:35 PM
  #1112
bankaiup's Avatar
CLOSE =)
remember when reving that high you're going to need a dry sump, oil cooler, MAJOR head work, HUGE cams,Big turbo to keep up LOL, so much stuff
OT
Im a huge dsm/sti junkie
I hate the usdm sti's because they come with a badass 6speed that was meant for 2.0
gears are short ...which means you need more rpm to compliment the tranny
The 2.5L redlines to 7k and with proper tuning and Money you can get a safe and strong 8k
the jdm 2.0 revs hits 8k, but i've seen them twist to 9500 and it's a FLAT FOUR
I love RPMs! the more the better. U can slap on any turbo and make use of it!
3076 has been proven on and off the track ie. road coarse, drag, etc
I have 5k rpms of full boost! ya know how much fun that is to drive?
  #1113
bankaiup's Avatar
back to topic... thats a great block, but if i had the money I'd just do a COSWORTH
at least you know it's dependable(to a point)
Old Apr 27, 2009 | 03:36 PM
  #1114
bankaiup's Avatar
HKS Kansai Service Crank - Good for 10K
Old Apr 27, 2009 | 03:46 PM
  #1115
Levar's Avatar
Veteran: Army
Originally Posted by bankaiup
thats pretty safe to say pistons and rods and all the bearings for a building the bottom end aka Short block.
To be honest though why don't you just save up a lil more and do it right!(i'm just ranting)
People don't think but the crank I'd say is the most important thing to mod!
Micropolish
KnifeEdge
Crossdrilled
Cryo treat it
Chemical treat it
by a new billet one!
ANyways just think what it'll be like to rev to 10,000 RPMS!
Then build from there!
Remember to also hone your block and get it balanced and blueprinted!
CLOSE =)
OT
Brother, I just had to laugh at how quickly the parts started to add up. I'm like as the list grew, and grew, and grew. Let me chill out before my misguided zeal get the best of me. Bottom line, I want 500+whp with as close to 500wtq as possible on about 30PSI and I believe the HTA3076 with the 0.63 turbine housing will do the trick. If I need the additional torque, I can easily drop in some meth and call 'er done. I'd also consider E85 with map switching as an alternative. I posted a nice dyno chart in this thread that showed what it's capable of doing on a Mustang dyno.
Old Apr 27, 2009 | 03:59 PM
  #1116
bankaiup's Avatar
well every dyno is different no matter what right?
for instance
Turbochargers Mustang dyno read 5% lower than a Protech's Dynjet
but MZM is 20% lower than protech's and it's also a mustang
Peak boost and tapered boost at 30psi?
Myself i run the 3076 I peak boost at ...actually heres a picture of 2 cars running the 3076 both are MAXING out the turbo btw
difference is one traps 127 and the other 131
Old Apr 27, 2009 | 04:08 PM
  #1117
monkey_187's Avatar
Originally Posted by wariosport
Good to know. I was planning on doing cams this summer.
Juts let me know when you are ready to put them in.
Old Apr 27, 2009 | 04:11 PM
  #1118
bankaiup's Avatar
his boost tapers at 28 and mine is 26, but i make more power and hold it!
reason? i have heads so they flow harder and faster
I don't exactly know what I'm trying to say but here it is
Forget about Numbers ... The measurement of HP on a dyno is worthless without TRAP SPEED
what is 500 hp? take any 500 hp Dynjet car out there they won't trap a 130 maybe a mid 120ish
E85 ..is by far the best thing that came to the autoindustry this decade!
105+ oct for under 2bucks ! saweetness
so if you want to run a high 10...yes a 3076 can do it! but thats with EVERYTHING done to ur car basically lol
FUELING! my kryptonite!
there was so many times where I've encountered this problem...not enough FUEL
a single walbro will not just suffice for my taste. I've only seen or read a couple of walbro crapping out....and I will not be that one=)
Check it walbro255 is not a true 255lph. If you do some research they are like turbos...they peak it but it doesn't hold and also not every walbro is the same...poor QC
I'll pm you my fuel setup
longstory short MONEY PIT! everytime you upgrade you'll find something else that needs money too! Bigger turbo, bigger cams, bigger fuelsystem...to much boost the sparks not keep up...need better ignition...to much power axles snapping ... better drivetrain, clutch dying can't hold the power...upgrading twindisk.. blah blah hehe
Old Apr 27, 2009 | 04:15 PM
  #1119
Darwinism's Avatar
COSWORTH FTW
Old Apr 27, 2009 | 04:26 PM
  #1120
bankaiup's Avatar
you forgot something
http://www.cosworth.com/shop_item.php?productid=398
4100 for heads
http://www.cosworth.com/shop_item.php?productid=456
9300 for 2.2l stroker
= ONE BAD *** *****!!!!!
Old Apr 27, 2009 | 04:40 PM
  #1121
Levar's Avatar
Veteran: Army
You fellahs are killing me softly all the way here in Kuwait with all of this stuff. I have so much more research to do and it really doesn't seem that a project will ever be done. Dang! So, with long-term investment as the theme, the HTA35r seems to be the route for me. What about the HTA3076 as I totally understand what you are saying about trap speeds? Joe, chime in as you see fit as you and a couple of the fellahs on here know how I can be at times.
Old Apr 27, 2009 | 05:09 PM
  #1122
bankaiup's Avatar
Various Cars Running this badass turbo!
E85, c16, pump whatever you want you got it!
PTE 6262
http://powerpages.tumblr.com/post/47...6262-turbo-kit
http://www.youtube.com/watch?v=e8YxTeuFMqs
http://www.youtube.com/watch?v=ms_MytG2mvI
http://www.youtube.com/watch?v=xuT3P5Sb2us
http://www.youtube.com/watch?v=2ApkHyiShGM
Old Apr 27, 2009 | 05:10 PM
  #1123
bankaiup's Avatar
For daily driver ...just get the 30r lol
Old Apr 27, 2009 | 05:24 PM
  #1124
Wick3d3vo9's Avatar
how hard is the double pumper install??
Old Apr 27, 2009 | 05:27 PM
  #1125
Levar's Avatar
Veteran: Army
4100 for heads
Ball bearing or journal bearing for the PT6262?
