South Region Includes AR, LA, MS, NM, OK, TX, NE, KS.
Ft Hood Evo Check-in
Old Apr 27, 2009 | 06:55 PM
  #1141
bankaiup's Avatar
request it i'm sure they can do something for you
Old Apr 27, 2009 | 07:55 PM
  #1142
monkey_187's Avatar
I guess the topic right now is engine build up bottom and top. Well Ill just say that in MY OPINION there are many options for us out there. Myself I think I will be sticking with Buschur. Reason being I baught his turbo setup even after everyone was telling me no and to keep getting ripped off by AMS. The turbo is amazing and I could be happier. All I can say is I have been ripped of like many other by AMS. Their turbo kits are capable of making more power with bigger hot sides, they know it but wount offer that option. All they care about is getting their name out there.
Originally Posted by eldiablo79
AMS gives a 10% discount to military also, have you thought about them? I was thinking about getting the HTA30, but I figured since I'm going to have a built block I should go much bigger.
A 10% discount isnt much when they are ripping you off so they make up theier money. I wont lie I once was an AMS fan but know I can stand the fact that I allowed myself to get ripped off by them. Crate motor for $14K without installation, f**k that! Buschurs sells for $5K and you get to pick the internals for your head, cams, gear, etc. WAY cheaper than the AMS rip offs..........
Old Apr 27, 2009 | 08:02 PM
  #1143
Sabot's Avatar
AMS or Buschur.......Who can you trust I heard crap about both and all the videos about Buschur in youtube. I guess is like any other business some people like you some don't. I just wish we had somebody near by.
Old Apr 27, 2009 | 08:25 PM
  #1144
xfactor evo's Avatar
i heard bad things about AMS engines blowing up... not sure how true that is though... i know their manuel boost controller sucks and wont let me past 24 psi...
Old Apr 27, 2009 | 08:45 PM
  #1145
EvoG8r's Avatar
Buschur all the way for me. Their motors are rock solid.
Old Apr 27, 2009 | 09:06 PM
  #1146
sith_killer_99's Avatar
Speaking of AMS, I was digging through their website today and noticed they have the mini battery kit. I'm sporting the RA and the MSRP is $179. Then I look it up for the Evo X and the MSRP is $149?!?!
I checked the specs, same dimensions, same power level, same setup? Thirty dollars more for the RA?
links:
http://www.amsperformance.com/cart/A...ttery-Kit.html
http://www.amsperformance.com/cart/A...mance.com.html
Old Apr 27, 2009 | 09:49 PM
  #1147
Darwinism's Avatar
Originally Posted by bankaiup
you forgot something
http://www.cosworth.com/shop_item.php?productid=398
4100 for heads
http://www.cosworth.com/shop_item.php?productid=456
9300 for 2.2l stroker
= ONE BAD *** *****!!!!!
That would be cool, but that would be a hell of a lot of work to swap a 4g63 into the X,
Old Apr 27, 2009 | 09:56 PM
  #1148
Sabot's Avatar
OK Is there any body in the Killeen area with a good tuning knowledge? I want to keep growing in this hobby of mine and my next step is tuning. Not trying to have somebody tune my car I just want to learn.
Old Apr 28, 2009 | 12:49 AM
  #1149
soceur77's Avatar
Originally Posted by monkey_187
Well guys soceur77 and I have finished putting his cams in, we had some problems but we got them in. First start up wasnt a good one but after we (I did most of the work) figured out the problem and retimed it, the car was running and sound good. Now all he needs is a good tune and his car will be even better. I never knew how easy it was to install them, I will never pay to have cams installed ever again. I could of saved so much money!
WARNING! Wall of text forthcoming...cliffnotes: cams are installed, LICP, arp studs, tbe, fuel pump,BOV also installed, I got tuned by kevind and Im happier then the guy that bangs Jessica Alby on a regular basis.
Monkey You did all the work??!!!! LOL Im getting you demoted from CEO of DD.
Well as already stated the cams are in. Was really an easy job. And to think, we saw a how to install cam video and was like hey we can do that....lol The bad start up after the cam install was due to a ID-10t error, but after some wtf! and damn its all around a corona and some Bob marley music in the back ground we fixed it in about 3o mins. We threw on the LICP ,and AP BOV and we were set. The initial drive was ok but it was sand baggin in the upper rpms. So today we decided to install the tbe. From here it got scary...as soon as I would start to run boost the car would hesitate and jerk. We figured it was just needing a tune. So I called Kevind and asked if he could sqaure me away today and he agreed. Although he felt that the car shouldnt be acting the way it was with what I had install. I drove up to Dallas, rather limped there and found that the car was in limp mode, but the reason for the boost reactions was due to the licp coupler not being the correct size, causing a major boost leak. The coupler used was the one I got from EPM. (Yea sabot I found the orginal...lol) By this time the car was runnning super rich, enough so that as he started the tune with me just idiling for about 5 mins while he tap away on his laptop I was creating a sidewalk of pure black soot. After a compression check, some new plugs and 7 3rd gear pulls he was done and i had the biggest grin on my face. Took all of 2 hours from start to finish. He cleared all the codes, the check engine light and gave me all the evo ecu goodies 2 step, overboost, raised rev limiter etc etc. Im running 23 pounds to 5300 rpms tapering to 16 pounds at 7000rpms. AFR are constant throughout the powerband. Big props to kevind for same day service and very good customer service and tips, such as if you ever blow of a IC pipe and cant put it on right away, you can disconnect ur maf and it will allow you to drive the car home or to the garage, just dont expect to win any races that way...lol Major props for my partner in crime in installations this 3 day weekend Efey Monkey CEO of DD....lol really though thanks Ceaser for the help and also kudos for his girl for keeping the drinks coming and our bellies fed. (Great cook) I dont know who has the fastest evo in Killeen, but i do know now that i dont have the slowest Holla at you boys later!!
Old Apr 28, 2009 | 05:21 AM
  #1150
eldiablo79's Avatar
Damn dude, I never thought I'd here the day you talk crap about AMS. You're a bigger fan than I am, you even got their clothing line up. But I don't think of it as getting ripped off, yeah it's expensive but you're paying for the quality and the name. I've gone to other places and seen other shops and I prefer their work. Not everything can be done at the Doper than Dope shop
Old Apr 28, 2009 | 05:32 AM
  #1151
eldiablo79's Avatar
So it all worked out finally, and nothing broke well that's good to hear. Sounded like it was some adventure. Wish I could of came over but I was stuck without a ride Now all you have to do is get your car lowered and take off that wing and you should be good There's just one thing, last time I went in for some work at the Doper than dope shop there wasn't any Bob Marley playing in the background, lol. The shop does do same great work though, once I was done I felt like the Dark Knight driving around in the F117
Old Apr 28, 2009 | 05:57 AM
  #1152
EvoG8r's Avatar
No, your best bet is Cobb Plano if you want an AP or KevinD for ECUflash who is also in DFW.
Old Apr 28, 2009 | 05:58 AM
  #1153
EvoG8r's Avatar
Soceur77, you chose wisely for your tune!
Old Apr 28, 2009 | 06:38 AM
  #1154
kevin installed my shep tranny duel plate and tuned it.... kevin-d FTW.
Old Apr 28, 2009 | 07:12 AM
  #1155
Sabot's Avatar
You see everything works out at the end I'm glad your car is running great so you could deploy happy.
