Fayetteville/Ft Bragg/Pope AFB -- TAKE TWO!!!
it seems so.... about to rinse off the ride and put some gas in it
.... i should be there right around 1 or really close. i think hector with the black ix mr se is coming as well to run. see you b1tches out there lol. hey bobby, give me a call when you are on your way...i figure you will be the first one there.
Eh, I had to make about 4 runs to finally get my boost dialed in and when I finally launched the car and was on my way to making a clean run the combustion cycle decided to break up under high boost. I'm pretty sure my plugs are fouled because it runs fine under 25lbs. I didn't even think to install colder plugs prior to going to the track. Oh well, just have to fix that for next time.
lol, yeah possible so, im giving classes this weekend if you are interested
you would of been on your way to a low 12 easily. post the videos if you can, upload to photobucket or youtube .....
be home around the 2nd of apr. lookin forward to lining up at the track 3-4 weeks after i get back and meeting some of you. hopefully we'll see some better times as you all make it through the summer........
matt... how much tire pressure were you running normally ? i cut down to 24, but i think i should of been 22 or close to it, maybe less.... traction was pretty good though, just et's weren't the greatest, i hit 115 or 116 i think, but 1/4's were a steady 12.3. i should of boost leak tested before as well and my boost wasnt quite right, was still getting a pause when it ramped at about 15psi before it opened all the way up which was killing my 3-4 shift. even no lift shifting didnt fix it, and i didnt want to run too many times to iron it out.
Now why would I spend 13 dollars a gallon on C16 when the Sunoco 114 works just as good at $6/gallon? I can pump 30psi on that as long as I have colder plugs in.
. yall better show up early so the SRT4's will park in the grass
