Fayetteville/Ft Bragg/Pope AFB -- TAKE TWO!!!
hell no !!! you suck
.... i wouldnt mind helping, just not sure how much time i'll have between now and then. Let me find out if my girl is working saturday... if she is, then we can knock it out then, otherwise i fear a long day at the movies
So you guys cool with the track on sunday and dynoing the friday prior ?
Bobby, do you have any big jugs to pick up gas out where you are at ? If not, maybe i can link up with you and give you a can and some cash and you can bring some by ? Let me know
C16 is leaded and will foul your O2 sensors if you use it often. If you only use 5 gallons of it you should be fine. It also has the tendency to break down your cat if you are running one...which I know must of us aren't
i will probably run the 103 i think... just let me know how much and we can figure out how we are going to do this.... i wanna try to make that pretty much the only fuel in my tank when i run... i may run a bit of octane booster in there in order to boost the 93 that is in the tank now. Hopefully we can get everyone there sunday, even if everyone isnt racing
Something Bad happen. I was at a stop light and when I took off a huge cloud of Black smoke came off my exhaust for a minute the car didnt want to pick up speed, so I threw into Neutral and then in gear and it was working right again??? what could have happen.
any weird noises maybe backfiring? Were you taking off hard or driving normal? Did it drive normal after that?
