Camp Lejeune/Jacksonville Evos
Old Jan 16, 2010 | 05:04 PM
  #5056
RaysEvoX's Avatar
Originally Posted by RREvoX08
What do you mean wrong part? how many X's were out there today?
Theres was 2. Myself and a silver one. The other guy ordered injectors and they sent him injectors for a evo 9 not a X.
  #5057
JReid's Avatar
you live in tt1, i live in tt2 side
Yeah right on, I live in TT1, right past the 4 way intersection that you come in through.
Old Jan 16, 2010 | 05:06 PM
  #5058
alicea8541's Avatar
Originally Posted by RaysEvoX
She put down 393whp and 330 wheel torque. Bobby said he left the the timing along because the stock fuel pump is still in it. It was a very funny drive home. Im very happy with it. Hopifully I can get up there again do get the cams installed and a 255 pump that actually works.
Very nice HP. Looking forward to see what she does when the cams and pump are in. By the way nice meeting you today. I was the one with the blue Underarmor hoodie next to you when your car was on the dyno. Names Ben.
  #5059
RaysEvoX's Avatar
Originally Posted by alicea8541
The silver one that went in before yours had a wrong part so they couldn't tune him. I sent this post when your car came off the dyno with the leaking injector.
Wrong person. lol He wasnt there.
Old Jan 16, 2010 | 05:09 PM
  #5060
alicea8541's Avatar
I noticed it was Luke after I sent it. I saw the first letter and thought it was Ray, going to fast.
  #5061
RaysEvoX's Avatar
Thanks, and it was nice to finally meet most of the J-ville Evo guys.
Old Jan 16, 2010 | 05:59 PM
  #5062
RREvoX08's Avatar
From: Tallahassee, but currently reside @ Camp LeJeune
nice ray, b&d has the walboro for 79 bucks, 255lt if your interested
Old Jan 16, 2010 | 06:43 PM
  #5063
RaysEvoX's Avatar
i have a walbro 255. ill be making a phone call to the company about it get a new one.
Old Jan 16, 2010 | 07:32 PM
  #5064
crewdawg130's Avatar
We got a lill plan for Bob's 500....
Old Jan 17, 2010 | 07:58 AM
  #5065
Psquared's Avatar
Yes sir..heading out to do some logs after the rain dries up some. I swapped out my forge spring too, so I need to fine tune the boost pressure again.
Old Jan 17, 2010 | 01:19 PM
  #5066
Psquared's Avatar
After boost leak testing my car, I found the EGR hose completely off, and the meth nozzle leaking too. I'm waiting on loctite to dry up and hopefully it seals it all up so I can pull some logs.
Old Jan 17, 2010 | 03:23 PM
  #5067
freshevo8's Avatar
Nice numbers and nice meeting you yesterday. When you get those cams in with the fp, your car is goin to be a street monster.
Old Jan 18, 2010 | 05:53 AM
  #5068
Psquared's Avatar
Just ordered a Hallman Pro mbc. Going to give it a try over the Forge mbc. Worse comes to worse, I'll sell one or the other locally.
Old Jan 18, 2010 | 07:23 AM
  #5069
tweaker41's Avatar
It's leaking from the check valve or fluid control system right? If so, just take that thing off and run the hose straight from the fail safe to the UICP. That's the reason mine didn't work that great and Sick9 had the same problem with his yesterday. As long as your pumps level with the nozzle or lower and you don't park facing down a big hill you won't have any problems.
Old Jan 18, 2010 | 08:21 AM
  #5070
Psquared's Avatar
Yeah, I talked to Justin that's what he said. I'm not having any issues with the push lock fittings. It's the actual threads where the nozzle threads into the uicp. I got it all sealed up with teflon tape and loctite. I re tightened ALL couplers on the intercooler piping the discovered my compressor cover was leaking from the seam where the bracket is that allows you to clock the turbo. I removed it carefully and put a bead of rtv on it per Blouch. I'm giving it a couple hours to dry, then I'm going to boost leak test it again. If it's sealed, she should be solid..except for my stock bov that leaks a bit.
