Camp Lejeune/Jacksonville Evos
Old Jan 18, 2010 | 08:33 AM
  #5071
Force-Fed Performance's Avatar
wtf?? u still got a stock bov
Old Jan 18, 2010 | 11:19 AM
  #5072
Psquared's Avatar
Yeah, I never bought the Forge RS because of reading threads about it bucking and stuff under part throttle. Was thinking synapse, but never bought one yet because I was waiting on more reviews of it holding boost, and how to fine tune the tension spring.
Old Jan 18, 2010 | 11:38 AM
  #5073
jesus, u shoulda said something. Ill take my own personaly forge RS off of my car when you come back to the dyno. When you see it holds boost better and there is 0 that is ZERO driveability issues with it, then you can buy it cause i dont need it anymore
Old Jan 18, 2010 | 02:08 PM
  #5074
alicea8541's Avatar
You know Bob has to have the perfect part. He will be looking for the rest of his life.
Old Jan 18, 2010 | 02:11 PM
  #5075
alicea8541's Avatar
But just to throw one in there for Bob's side. My stocker was holding up to 31 psi up until I took it out just to be safe. By the way Bob the Synapse would be perfect for you, easy adjustments if they are even needed.
Old Jan 18, 2010 | 04:30 PM
  #5076
synapse=fad
Old Jan 18, 2010 | 05:56 PM
  #5077
Psquared's Avatar
Yeah, like the best turbo...spools at 1500rpm and hits 40psi by 2k. lol
Ben, I'd like to bench test your bov to see what it holds. I built a small leak tester for mine, that's how I know it leaks. I'd be curious to see what your's holds.
Well, Today turned into a HUGE project. After leak testing & discovering the meth nozzle leaking, I found out that the compressor cover on the turbo was leaking air when you got up to 25 psi or so. Long story short, I pulled the entire turbo kit....manifold, licp, o2 housing, oil lines/coolant lines then the turbo. I called Blouch turbo & they suggested pulling the cover and using rtv to seal the seam of the comp. cover. I did all that & reinstalled everything in about 3 hours. My hands are cut to h*ll & I don't want to look at that thing for like 3 days... lol
Old Jan 18, 2010 | 06:05 PM
  #5078
crewdawg130's Avatar
im sorry about that but thats good news tho
Old Jan 18, 2010 | 06:09 PM
  #5079
that RTV isnt going to seal that turbo for a long time tho, keep an eye on it
Old Jan 18, 2010 | 07:07 PM
  #5080
alicea8541's Avatar
Originally Posted by Force-Fed Performance
synapse=fad
Yeah but a fad is usually a good thing in the car world.
FP Turbos
Cossie Cams
GSC Cams
Kelford Cams
Buschur parts
AMS parts
ETS parts
List goes on and on. If it is hot today it's because it works. Why wouldn't you buy what works?
Old Jan 19, 2010 | 06:07 AM
  #5081
Psquared's Avatar
Yeah, I know..i guess it's a band aid. I don't know what to do about it...it's not a huge leak, I had to use water to locate where it was coming from..but a leak none the less. Blouch said Garrett machines the surfaces to seal, & I've never noticed it before.
Old Jan 19, 2010 | 09:52 AM
  #5082
RREvoX08's Avatar
From: Tallahassee, but currently reside @ Camp LeJeune
so after a day of doing taxes, my $11,000 will be here on the 29th!!!
Old Jan 19, 2010 | 09:53 AM
  #5083
WOW i wanna loan
Old Jan 19, 2010 | 11:50 AM
  #5084
stock_evoIX's Avatar
holy moly
Old Jan 19, 2010 | 12:57 PM
  #5085
bigric09's Avatar
do you have 75 kids ?
