ALABAMA.. who is all here?
XS, you sure the air is pushing through the head and out the exhaust? The only reason for that would be:
a) Valves not seating
b) valves are in overlap in the stationary position
There are no other explanations that I know of. I've never seen it happen though. I always test from the compressor and leave everything but the intake connected. This tests the entire pressure system, BOV, IM, head, pipes, BC, everything.
The only think I'd suggest trying is bumping the engine over and trying to test with the crank in a slightly different position.
Oh, what method are you using to pressurize the system? Air tank? Shop compressor?
Only one set has to be seated to seal the head ... it should only leak a notable amount if a cylinder is in overlap with both sets of valves open. That would only happen for a brief moment at the end of the exhaust/beginning of intake stroke, depending on cam selection and cam gear/MIVEC settings.
ah, I'm with you.
If you had low compression the air wouldn't come out of the exhaust.
Honestly, I think you lack pressure to fill the system. I haven't had much luck doing tests without at least 80 psi ready to go in a tank. I use a small 5 gal portable tank for this, but any large shop will have a 100 gal+ tank with plenty of pressure to spare. If you are trying to pressurize while a compressor is running with no existing pressure, that will not work.
Interesting. I think the samething is happening to me.
^^ ive seen you around a couple times... waved but you never waved back!
and if you need someone to put in that clutch let me know! i own a transmission shop ill make you a deal!!
