ALABAMA.. who is all here?
Old Dec 24, 2009 | 08:42 PM
  #1756
linuxman51's Avatar
murrah crimmus yallll
Old Dec 24, 2009 | 08:48 PM
  #1757
Demon_ni2's Avatar
nice.. nothin but redneck in that marry christmas.
Old Dec 24, 2009 | 09:09 PM
  #1758
rayman0690's Avatar
Merry Christmas everyone
Old Dec 25, 2009 | 06:14 AM
  #1759
linuxman51's Avatar
you know it
Old Dec 25, 2009 | 02:01 PM
  #1760
Q@EvoPowerMods's Avatar
Kenny How's the clutch working out? You get it installed yet?
Merry Christmas Everyone !
and
Here's Hoping that 2010 will be a great New Year !
Old Dec 25, 2009 | 03:27 PM
  #1761
linuxman51's Avatar
and
its doing a wonderful job of holding the hearth down right now. transmission is in ohio
Old Dec 27, 2009 | 11:03 AM
  #1762
Demon_ni2's Avatar
HAHa.. so motors all torn down(took me about 30 minutes, i left the cam/cam gears in the head, disconnect and removed everything i did need), umm.. anyone have an good suggestions on getting the crank pulley off? im about to give up on that, flywheel crank and crank pulley r still on(so is the timing belt since i cant get crank pulley off). i dont have an impac. and its on an engine stand, donno how to get it off.
Old Dec 27, 2009 | 05:55 PM
  #1763
linuxman51's Avatar
air impact, or figure out some way to keep the crank from moving and the engine from falling off the stand.
Old Dec 27, 2009 | 06:06 PM
  #1764
Demon_ni2's Avatar
i dont have an impact or a air compressor
Old Dec 28, 2009 | 06:21 AM
  #1765
loofee's Avatar
use the 1/2 inch rachet and brack it with a jack stand then tap the starter( assuming the engine is still in the car), if not, try to find a way to lock the flywheel ( in ur case the plate that holds the converter) and use a big ole braker bar!!!. C
Old Dec 28, 2009 | 08:12 AM
  #1766
linuxman51's Avatar
and try to keep the engine stand in the correct orientation. That will likely be the most difficult part of the whole thing.
Old Dec 28, 2009 | 01:05 PM
  #1767
Demon_ni2's Avatar
arg. ya.. keep stand still while i try to break it loose it definately the hard part. i took a break for now. i got till next monday to get the crank pully off.
Old Dec 28, 2009 | 05:48 PM
  #1768
I forget.... but is the thread on the bolt to pulley... right hand or left hand thread? Will def make a difference when loosening...
Anyways--->Kenny I need your Help with my Palm Pre..it's Linux based, are you familiar with "Virtual box" I'm trying to add a few things to the operating system and can't seem to make it work.
Old Dec 28, 2009 | 07:32 PM
  #1769
linuxman51's Avatar
I haven't messed with anything palm in a while, I'd have to look into it. it won't let you? or it isn't working? if its just not working, could be dependencies or incorrect version of the firmware.
Old Dec 29, 2009 | 07:11 AM
  #1770
evoWWrs's Avatar
best way to do it is stock something strong thru the flywheel to keep it from moving and then using a breaker bar and put your weight into it... itll come!
