Camp Lejeune/Jacksonville Evos (NEW)
Old Jul 18, 2010 | 04:55 PM
  #751
crewdawg130's Avatar
Originally Posted by SRTRaceR04
Nah none of it did any damage thankfully.
Got it fixed and back on the road around 730. Feels much better. Even the manifold bolts were kind of loose. Not sure what the last owner did, but they did a ****ty job.
nice to see you gotten taken care of
Old Jul 18, 2010 | 07:39 PM
  #752
SRTRaceR04's Avatar
I dunno about what everyone else is getting MPG wise, but I'm still getting bad gas mileage even with a tune. It may have actually gotten worse. I literally go through about a quarter of a tank of gas round trip driving from my house in Hubert to Best Buy in Jacksonville (about 12-13 miles one way I think).
And that's with ZERO WOT. I drive my Evo slower than I drive the Fit.
Old Jul 18, 2010 | 07:47 PM
  #753
RaysEvoX's Avatar
Thats horrible gas mileage.
Old Jul 18, 2010 | 07:50 PM
  #754
Spec-OpsMotorsports's Avatar
We can get that bad boy squared up for you. Tuning for driveability, performance and gas mileage is what our reputation is all based on
Old Jul 18, 2010 | 08:35 PM
  #755
XSboosyed10's Avatar
Yea man that aint good. I make the same drive and my gas hand barely moves at all.
Old Jul 18, 2010 | 08:36 PM
  #756
SRTRaceR04's Avatar
You're telling me. I can borderline watch the gas needle move downwards as I'm driving.
Put it this way, my car gets similar mileage to my brother's Supra. His car has a fully built head and ZERO tune. The gas damn near drips out of the muffler it runs so freaking rich.
Car still feels kind of blah without boost. Not sure how to address that, but I just deal with it now. The MPG is definitely something I want to address when I can cause gas isn't cheap!!
Old Jul 18, 2010 | 08:41 PM
  #757
Force-Fed Performance's Avatar
Dan,
With the exhaust leak you described(prior to the upstream oxygen sensor) your short term fuel trims will be ALL out of wack. This is also due to the hot/humid summer we are having and the ecu is seeing higher Intake air temps than normal.
Old Jul 19, 2010 | 03:57 AM
  #758
RREvoX08's Avatar
From: Tallahassee, but currently reside @ Camp LeJeune
Ray, so i finally had time to look into the shifter issue, and the rear shifter cable underhood bushing popped off, so i gotta order a new set, but i have it fixed with the stocker bushing for now..
Old Jul 19, 2010 | 08:37 AM
  #759
RaysEvoX's Avatar
That sucks man. I wonder how it popped off. The little cotter pin(if you want to call it that) was on there tight.
Old Jul 19, 2010 | 03:35 PM
  #760
SRTRaceR04's Avatar
Now I'm throwing P0137. I'm guessing the car didn't like the exhaust leaks. I know the gaskets around the straight pipe need replacement.
Old Jul 19, 2010 | 04:32 PM
  #761
SRTRaceR04's Avatar
Ok plugs needed to be replaced since I'm running the cheap ones. My question:
BPR8ES or BR8ES??
I have the SpoolnUp COP so what gap am I looking at for the more appropriate plug? I had BPR in there, but I just want to make sure that's the right kind.
Old Jul 19, 2010 | 04:36 PM
  #762
bpr with about a .028 gap will be fine
you really shouldnt need anything tighter than .025 with that cop. the BPR run cooler than the br i believe anyways
Old Jul 19, 2010 | 06:02 PM
  #763
SRTRaceR04's Avatar
Thanks, good info to know.
My only main gripe is the way the car feels all the time. Its always like my tunes don't hold or something. It usually feels good right after my Dyno tune, but after a couple wot pulls it starts to feel slower. It basically is back to feeling as fast as when i had it tuned originally...when it made like 350whp.
Like I could barely put like a car and a half on my buddies STi which made 360 over at epic. And he said he was only running spring pressure. So I've been pretty disappointed lately with the car....
Old Jul 19, 2010 | 06:07 PM
  #764
tweaker41's Avatar
There's some underlying issue if that's the case, the tune isn't going to go bad. It could be plugs, boost leak, gas, etc. Do you fill up at the same gas station?
Old Jul 19, 2010 | 06:48 PM
  #765
SRTRaceR04's Avatar
No the gas stations vary. But it's pretty consistent between a couple of them.
And I know it needs a boost leak test done, but I don't have a boost leak tester as of now. Even off boost the car sucks. Like keeping up with traffic requires me to rev it up a bit.
