need help to avoid engine light problem
Old Apr 6, 2009 | 08:10 AM
stitchflip's Avatar
I'm picking up my SRI today after work and I plan on installing it maybe tonight and tomorrow..if anyone can tell me how i can avoid the engine light problem (or maybe a thread that discussed this matter already), it would be greatly appreciated..they SRI is a F5 Fujita SRI.thanks in advance!
Old Apr 6, 2009 | 08:30 AM
evo_soul's Avatar
If you remove your intake the light should go away. The Fujita design at least for the first and second version for our lancer is flawed. It sometimes briefly strays beyond the MAF sensor threshold parameters and triggers a soft (pending) code. In a nutshell the airflow gets disrupted now and then and doesnt hit the MAF sensor right. The ECU sees this and makes a note of it with soft code. Soft codes can disapear and re appear. Its just a little never racking when you see them.
In theory, you should be fine, so long as your getting the performance gain.
If you need assistance in terms of diagnosing the code. We the car club offer ScanTool Services, pricing hasnt been finalized yet but basically if you make it to the meet, its 15 bucks, but you will A) get all the codes pulled for your car and the freeze frame of them as well. you can view that info and make an informed decision on how you would like to proceed. B) you can clear the code when your done.
You can also rent the scantool by the hour if you wish to do longer field testing. ScanTool is completely unlocked and will show everything within the Mitsubishi ECU, the list is huge well over 100 sensors. EVO X or Lancer , or older lancers, its all unlocked So we can take the car on the road, hunt for that trouble some code, record and chart out your fuel trims/ o2 readings, RPM speeds, throttle position, transmission operations... everything.
Hope that helps. Come down to our next meet or PM me if you want to meet up
Old Apr 6, 2009 | 12:19 PM
stitchflip's Avatar
Awesome. Thanks a lot! I'll let you know if I enconter the problem after installing it.
Old Apr 7, 2009 | 05:25 PM
stitchflip's Avatar
I just want to give you an update - I did not get the service engine light problem after installing the SRI - which is awesome.
I was holding my breath as the mechanic starts the car..It got me really worried that he didn't disconnect the negative terminal on the battery before pulling out the mass sensor.
overall it went well.
Thanks for everything - lookin' forward to the meet!
Old Apr 8, 2009 | 06:49 AM
evo_soul's Avatar
from what i hear about Fujita intakes is the soft code is triggered over time. and can come and go on its own. Good luck, maybe it might be just fine
Old Apr 8, 2009 | 08:56 AM
stitchflip's Avatar
I hope that never happens coz i'll go mental...but if it does, I can always come to you for help. ; )
Old Apr 8, 2009 | 09:25 AM
evo_soul's Avatar
even if it doesnt it doesnt mean a serious problem, its just an issue with the way the air hits the sensor, if its off by a little one or two times it will hit the soft code threshold.
Old Apr 8, 2009 | 01:04 PM
stitchflip's Avatar
and it will go away by itself as soon as the air continuously hits the sensor again? so nothing to worry about when all of a sudden the CEL flashes on?
LAY6C
Toronto Lancer Club
Apr 2, 2012 08:18 AM
ShadowES
Lancer Engine Tech
60
Nov 17, 2009 08:37 PM
08MitsubishiGTS
May 15, 2008 11:22 PM
modelchris
Apr 20, 2005 02:33 PM
dewman1999
Lancer Engine Tech
May 28, 2004 06:22 AM
