side signal indicator removal
Old Jun 5, 2009 | 06:45 PM
OctaneX2's Avatar
anyone know how to remove the transparent cover on the side signal indicator as I would like to put some white leds there, but having trouble finding a way to get the cover off.
Old Jun 5, 2009 | 07:48 PM
laksman91's Avatar
i think its meant to be one piece
Old Jun 6, 2009 | 12:36 PM
aj_pierce's Avatar
The Clear plastic and the bulb are one piece. Actually the Bulb is sealed inside the indicator.
But it you wish to try, Just slide the marker toward the rear of the car and you should have enough clearance to pull it out. Its secured by a compression style design so when you slide it to the rear the clip will depress and should just pop out. Then you remove the wire harness. I'll go snap a pic so you can see.
EDIT WITH PICs:
Old Jun 6, 2009 | 04:33 PM
OctaneX2's Avatar
EDIT WITH PICs:
Thanks but I know how to get that off, I was wondering how I can get the casing off of it to expose the bulb but I guess its really not meant to come apart. lol
Old Jun 6, 2009 | 06:23 PM
three29's Avatar
well the manual says its not meant to be taken off.. damn mitsu they want us to replace the whole piece with a new one when ours burns out... i wouldnt risk taking it off, unless your stock bulb burns out, in which case ur gonna hve to replace it anyways, then give it a try.. hahah you can put it in a toaster oven and try to bake it off or something LOL
Old Jun 6, 2009 | 10:17 PM
aj_pierce's Avatar
A small toaster oven pre-heat to 200 let bake for 5-6 minutes should be safe, should being the key word, Worked with the head light anyway. but the thing is so delicate and small I wouldn't even bother nor would I recommend it, unless like three29 said unless your willing to replace it".
Price it out first
Old Jun 6, 2009 | 10:50 PM
OctaneX2's Avatar
ya ok thanks guys I think I'll just leave it then there seems to be too many maybes and id rather not take the risk
nekkidlad
10
Sep 11, 2015 05:16 AM
bnr34rb26dett
Apr 5, 2012 01:08 AM
llno24
10
Sep 14, 2010 10:58 PM
OZ_racing
Lancer Troubleshooting
Sep 10, 2009 11:23 AM
Tweak3D
Nov 29, 2007 11:06 AM
