New Magnus Motorsports Cast Aluminum Intake Manifolds Available @ MAPerformance!
Old Oct 14, 2008, 04:19 PM
maperformance's Avatar
Modern Automotive Performance is proud to be the first shop in the country to get our hands on this amazing offering from Magnus Motorsports. Units are in stock and ready to ship!
Click on the dyno charts above for a larger view.
(Left: Stock Turbo / Evo OEM vs Magnus Cast)
(Right: GT3037 Turbo / Evo OEM vs Magnus Cast)
Magnus Cast Aluminum Intake Manifold $999 Shipped
Includes adapter to suit stock or 75mm+ throttle bodies / throttle body gasket / heat barrier gasket to head / hardware!
Over 10 years ago, Magnus Motorsports released its first Sheet Metal Intake Manifold into the market place and it quickly became the standard within the Mitsubishi Racing community. After almost 2 years in development, we would like to introduce you to the next big thing. The Magnus Motorsports Cast Intake Manifold.
Magnus designed this one from a fresh sheet of paper. Out of over a dozen prototypes, endless testing and perfecting, the Magnus Cast Intake Manifold was born. They applied our years of experience from crafting thousands of sheet metal intakes and once again have raised the bar for power and quick response. By applying a unique design and a massive 5L plenum, this cast manifold means big power and big power sooner!
Cast in A356 Aluminum with a wall thickness of 3/16"; the Plenum shape features a varying contoured tapered profile at a volume of 5 liters. The runners themselves are completely revolutionary in their design; featuring an integrated velocity stack that gradually transitions into the head port profile. It was designed entirely against the shape of the original cylinder head port taking advantage the 10° port entry of the EVO head maintaining un-interrupted laminar flow. The Magnus Cast Intake Manifold will work with throttle bodies from stock right up to 100mm and have seen consistent gains from 30 awHp to 52 awHp with varying setups. Transient boost response is exceptional and it can bolt together in a stock location if required while still being able to be used on a full blown race application.
Cast Intake Manifold Features:
* 2 years of research and development
* Cast from A356-T6 Aluminum Alloy
* High quality casting gives a superior surface finish
* Enhanced flow dynamics utilizing CAD Modeling & CFD simulation
* Flowbenched and dynamically tested
* Dynotested proven up to 50 HP
* Ability to flow 100 lb/min (1000 HP) of air at 60PSI while maintaining equal flow distribution
* Can be installed in stock location with clearance for original battery (with adaptor)
* Install kits feature dipstick tube adaptor, remote map sensor boss for use with factory ECU’s
* Stock turbo gains up to 40HP
* 15 degree entry to the throttle body facilitates intercooler plumbing
* Can be configured for 8 injector setup.
* Fits factory fuel rail or Magnus high flow fuel rails
* 5L plenum with contoured velocity stacks molded into the floor for huge top end and minimal turbulence
* Magnus Quality and Lifetime warranty
maperformance is offline
Old Oct 14, 2008, 04:23 PM
Billy@EnglishRacing's Avatar
I have one on the way! Can't wait to slap it on and get to the dyno!
Billy@EnglishRacing is offline
Old Oct 14, 2008, 04:46 PM
wshihdnevo's Avatar
^Me too...
wshihdnevo is offline
Old Oct 14, 2008, 04:52 PM
EvoDan2004's Avatar
do i smell another intake manifold testing session in the future???
EvoDan2004 is offline
Old Oct 15, 2008, 07:28 AM
Quite Possible!
Old Oct 15, 2008, 05:53 PM
PM's responded to, thanks guys! Try and ask questions regarding this piece in the thread so everyone can see the responses!
Old Oct 16, 2008, 09:25 AM
Bump.
Old Oct 16, 2008, 04:57 PM
Bump to the top
Old Oct 16, 2008, 05:10 PM
Sharkbite2000's Avatar
So this will not crack under pressure?
44+ DAILY ?
Sharkbite2000 is offline
Old Oct 16, 2008, 05:48 PM
Kracka's Avatar
44+ DAILY ?
This should be stronger than any sheet metal intake manifold.
Kracka is offline
Old Oct 17, 2008, 11:01 AM
What he said lol.
Old Oct 17, 2008, 11:57 AM
MAS2377TECH's Avatar
Location: Philly, Germany, Japan, UK...South Dakota (Da Sticks).......
Anything for Evo Xs yet?
MAS2377TECH is offline
Old Oct 17, 2008, 01:11 PM
Nothing as of yet but I can imagine that a lot of people already have something in the works!
Old Oct 17, 2008, 03:21 PM
Bumpin!
Old Oct 17, 2008, 03:30 PM
Originally Posted by maperformance
What he said lol.
So does it come in black ?
And if it does break under extreme boost do I get it for free ?
Quick Reply: New Magnus Motorsports Cast Aluminum Intake Manifolds Available @ MAPerformance!
