MAP crankcase vacuum kit
Car I had a set in kept blowing the dipstick out. Took them out and it stopped blowing out... They were facing the right direction too.
These things don't flow enough volume to be used in a PCV system and the intake will NEVER suck enough air to put vacuum in the crank case on a four cylinder built with tolerances to make power anyway. Route your lines to a can be vent it to atmosphere is the best you can do.
RussellM
MitsubishiParts.net - WA
Jul 20, 2015 04:48 PM
vtluu
Aug 10, 2006 08:56 AM
