Vishnu/Dyno4mance April 2-4 update
Old Apr 3, 2005 | 05:01 PM
  #121
EVO MR's Avatar
I just got back from the dyno day (took me 10 hours to get home )
05 MR with stage 1++
on 93 pump 300.6 awhp and 280 tq
I'm happy, car pulls very well
Old Apr 3, 2005 | 05:02 PM
  #122
Az3ar's Avatar
Originally Posted by BADEVO
Which one is yours? I prob have a couple of pics of it.
It was nice to meet you bad EVO
Well as I told everyone there including Mrs Seth (I got ****ed)
I will be watching the stage 2 (Vishnu) and if things don’t go well I will have to put stock turbo on with 10.5 housing and 272 cams before the next dyno day.
Shiv I don’t know why I am throwing code PO172 but I think it has something to so with the forge BOV so far. I have no air leaks or boost leak but I do have BOV surging and that might cause the issue so let me know what you think.
I did not make the power I was hoping for and surprising I made exact same power I made in Cali on 91 gas and stock cat. I have no explanation but I will be changing the kit soon.
Andrew thanks for your great help and for your great work.
Seth 2 words for you (you suck)
Will see what happens good luck everyone.
Old Apr 3, 2005 | 05:29 PM
  #123
Noize's Avatar
EvoM Administrator
Mhyar: Two words for you, friend: 16G, beeotch!
Old Apr 3, 2005 | 05:42 PM
  #124
EVOtagger's Avatar
mhyar...what did you end up putting down?
Old Apr 3, 2005 | 05:46 PM
  #125
Az3ar's Avatar
323 on race and 293 on 93.
Old Apr 3, 2005 | 05:48 PM
  #126
Az3ar's Avatar
BTW I need a pic of your turbo to see what stud is broken. it comes with the o2 housing right? Seth PM me with your number we got to talk .
Old Apr 3, 2005 | 06:02 PM
  #127
EVOtagger's Avatar
dang man...i hope you get everything figured out with it
Old Apr 3, 2005 | 06:16 PM
  #128
BADEVO's Avatar
Sure do, check out my album on 4G63HP.com tommorow for a couple more.
Old Apr 3, 2005 | 06:29 PM
  #129
Az3ar's Avatar
Nothing to figure out, I just want the PO172 code to go away. Its not like it’s not fast but it's disappointing for sure. I will have to leave it a lone for a little while as I have to focus on a new job I am getting. I just want to make sure it's running fine that's all.
Old Apr 3, 2005 | 06:39 PM
  #130
Jorge T's Avatar
What do you think is triggering the system too rich code? I don't think the BOV would do that unless it is VTA.
Old Apr 3, 2005 | 07:15 PM
  #131
wthoevo8's Avatar
It looks like the same #s you put down at Vishnu awhile back. No additional mods???
Old Apr 4, 2005 | 03:25 AM
  #132
Az3ar's Avatar
Exactly, I don’t know what’s causing my ECU to see the rich condition. I called Shiv and he said I might have a boost leak but I spent 2 hrs last night under and over the car looking for every hose on the car and I found nothing (I am still boosting my normal 23 PSI holding). I asked Shiv about a copy of my F/A graph because I have not received a copy (but what do I know). He said that the maps have not been touched (original from Cali) which is weird to me as I thought 93 gas will make a bit more power (oh well it might be the turbo). I don’t care about the numbers as I believe it’s a bit decent but I just want it to run right. On the other hand I will see Shiv next week in NJ so it's not an issue here (I am sure he will do whatever he can to solve my problem).
Off to DC for my big show see ya guys.
Old Apr 4, 2005 | 03:26 AM
  #133
Az3ar's Avatar
beside now I have no cat and 93 gas and manifold.
Old Apr 4, 2005 | 06:02 AM
  #134
rich728's Avatar
I finally found a bypass valve....not from a dealership (nearest instock is in Colorado), but from a guy on nasioc. I'm waiting for him to take a break so i can get it. Guy works at a hospital.
Old Apr 4, 2005 | 06:07 AM
  #135
Ted B's Avatar
313whp 93 oct
348whp 93 + Methanol
16G (TME) turbo
