Guys, NEED HELP, Inspection time!!
Old Mar 22, 2005 | 09:45 AM
YEVOVIII's Avatar
Hey fellas, I need your help. I have the Vishnu Stage 1+ and my inspection is due at the end of this month. I am running catless and so of course I am throwing the CAT code. I have tried the mech fix using the anti-fouler but it did not work. I know that i have to put my cat back on for visual inspection but I want to make sure I will pass. A good friend of mine has a pocket logger and can erase the code and it stays away for about 50 miles. I have heard two different stories using this method to erase codes. One person has said that it will work and the factory computer will say," READY". Another person has said that it will not work and when you use the pocket logger to erase the cel the factory computer will say, "NOT READY".
Anyway, I am trying to find the best way to get rid of the CEL for inspection. I know that Vishnu has the elctronic fix for 80 bucks. Has anyone used this and does it work. Please help
Tony
Everything that i have stated above is pure Fiction. None of it is true. So if you bastrds are watching(you know who you are) my car is 110% street legal.
Old Mar 22, 2005 | 09:47 AM
ultraflip's Avatar
once you put the cat back on for "visual purposes" wouldn't that erase the CEL as well?
Old Mar 22, 2005 | 09:52 AM
YEVOVIII's Avatar
I am not sure that the Vishnu cat wont throw a code. Its hiflow so a lot of people have have the CEL come back up
Old Mar 22, 2005 | 09:54 AM
superman105's Avatar
go to Autozone and rent a OBD-II Scanner for FREE
and erase the code AFTER you install the Anti Fouler
the Cel code will not disappear by it's self. you would have to clear it and it should not come back if you clear it after you install the ANTI FOULER
Old Mar 22, 2005 | 10:00 AM
YEVOVIII's Avatar
I got the code after the cat came off. Went to my friends house and erased the code and installed the anti-fouler. Came back 40 miles later.
Old Mar 22, 2005 | 10:05 AM
zilla killer's Avatar
PM I can help you.
Old Mar 22, 2005 | 11:14 AM
YEVOVIII's Avatar
Zilla, I PMed you. Can anyone help PLEASE?
Old Mar 22, 2005 | 11:17 AM
EVOTEXAS's Avatar
Tony, you do not have to drive 50 miles to have the ECU say ready. Just clear the code down the street from the inspection joint. I have an OBDII scanner and I clear the code and it still says ready. If you want to stop by we can test it on your car. Come by when the light is lit.
Old Mar 22, 2005 | 11:33 AM
Jorge T's Avatar
Vishnu CEL eliminator is the ticket. If the one antifouler won't work use 2 this usualy does it.
Old Mar 22, 2005 | 11:39 AM
bdking57's Avatar
Seems like it would be way cheaper and easier to pay someone off..
Old Mar 22, 2005 | 11:41 AM
gsujeff55's Avatar
yeah, how many antifoulers are you using? you need 2. i have not had a single problem with mine. no light what so ever.
Old Mar 22, 2005 | 11:52 AM
same here I used two and never had a cel light it's been 3000 miles
Old Mar 22, 2005 | 12:17 PM
YEVOVIII's Avatar
Thank fellas for all the help!!!
Old Mar 22, 2005 | 12:21 PM
an0ther's Avatar
ive never had a light since i had 2 foulers. and btw what you do is tell them that your battery died last night and that is why your computer was reset. I thought it was 500 miles and not 50 miles.
