White Rabbit Turbo
If were lucky, there will be both a rabbit and a 3071 setup at the SoCal Vishnu dyno day on July 10th. However, the 3071 will be an AMS kit that will be installed on my car.
I don't think anyone will have the Vishnu Stage 2 for this day...
Originally Posted by Ludikraut
It will be very interesting to see how the white rabbit stacks up to a 3071 based setup, but for right now there just isn't enough information - no compressor map, not enough dyno sheets, not enough cars. Let's hope the white rabbit doesn't turn into a white elephant
l8r)
l8r)
I WILL HAVE the White Rabbit. No cams, though...
Originally Posted by Dyno4mance
I will do my best to accomodate you Dude.....50% discount on Dyno time goes to the first Xede equipped evo with a white rabbit installed....I would also like to do a comparo on this turbo
Stop trying to seduce me to the darkside
I wanted a set-up that looks stock. Now I have to put in a fuel pump and injectors. I don't need to "maximize" things right now.
My next mod after this is to learn how to drive this darn car property. I wasn't paying attention yesterday and I almost experienced lift throttle oversteer getting onto the 101 (shifting from 2nd to 3rd). The car got real light for a second. I would have felt like one of those 18 year old kids who wrecks their Evo the first week.
Cams will make this too much car for me in a track situation. For now, not cams. I ain't takin' the valve cover off. You guys are the worst
Peer pressure sucks
Peer pressure sucks
Peer pressure sucks
Peer pressure sucks
atlvalet
I just ordered my WR
will be running HKS 280 and Alky kit + Smart Xede at the S. Cal Dyno day !
July 9 I'm right after Smog
by the which injectors are you getting
I'm thinking of getting the 660s Tym mentioned, although the Buschur 680s are another consideration. I'm also contemplating dropping my car off at RRE for the no name clutch in the next few weeks.
That set up with alky will be insane numbers. Way too much car for me though. I think a new clutch is in your future
Also, FYI, I will have a Buschur coated/ported stock exhaust mani on my car.
Peer pressure sucks
Peer pressure sucks
As far as power goes, all you need to do is run your 91 octane map when you go to the track. When you start feeling confident, you could then up the octane to 100 to start kicking some ****.
I can promise that you will be pissed off once you see people buying white rabbit turbos and making more power than you with just a set of cams. Then you will be trying to play catch up with them...
You're trying to convince yourself... no one here's buying it. You could argue "it's too much car" right now. Cams will help overall turbo performance , not just power. If your broke because of buying a new turbo before buying less glamorous cams, I would belive you.
