Stage 2 Turbokit v500
Originally Posted by Jaylenospoolboy
You get an upper IC pipe and injectors. Back them out and there's your $3500.
I'm wiped. It was 100 degrees at TT today.
Mad props to Chris and Alfred, David, Dustin, Calvin, Isaac, Kim, and Shiv............... and SSSmmmmmmmmmmmmoggy!
Stage Two (v550)
Includes:
Garret GT Turbocharger System
Upgraded Fuel Injectors
Signature Series 3-inch Down-Pipe
Lower intercooler pipe
Tial wastegate
Slimline 12" radiator fan
Performance:
0-60mph in 3.1 seconds
Standing ¼ mile in 11.4 seconds at 125mph
Installation difficulty:
Advanced
Estimated Installation Time:
8-12 hours
Where's the upper intercooler pipe?
Originally Posted by statix
The funny thing is, your kit looks just about identical to atp's kit.
Your adapter piece is basically what atp's houising is, even the dump tube is a slipfit to the downpipe. Im surprised no one else has noticed the simularities.
I definitely dont see how Vishnu's kit could dominate atp's kit, wheres the difference(besides being twice the cost).
All Vishnu kits use an unadulterated pure Garrett Ballistics turbo. Half the ATP turbo is not Garrett, it is an ATP casted hotside that is not efficient from what all have seen.
Jaylenospoolboy's car made 372whp, 318torque on straight 91 in 103 degree heat. The turbo spooled quickly and held boost.
Originally Posted by shiv@vishnu
Here's Stg 3 (Stg 2 plus 321ss short runner tubular manifold):
http://www.vishnutuning.com/evo_Stage3_v550.htm
Shiv
Shiv
What turbo do you use on your stage 3. Is it still a GT3037 or a bigger GT35R??? How much price increase compared to Stage 2???
***Shiv can you pm me the price of your Stage 3 turbo setup???***
Originally Posted by RACESHOP
I think he meant Intake tube,Its 3" aluminum with BOV recirulation tube that will work with the stock airbox.
And Larry, a wonderful piece of work I might add
Everything sits flush and looks stockish.
The side effect of the aluminum instead of the stock rubber unit is you can hear the twin plate more now. It now sounds like a medium sized box of rocks instead of a small box of marbles.
Just got back from TT and had the wastegate buttoned up. Alfred and Chris retuned the car. Picked-up 40whp on the 91 map and a few more on the others maps...and spool up 600 rpm earlier (about 12 psi) at 3800 rpm. The kit holds power to the redline.
Dyno graphs will probably be up tomorrow. When they come up, look at how many rpm Chris starts the run at and how fast the turbo jumps.
The ATP kit could throw down when needed, but the power band was narrower and it wasn't put together quite as well as this one. However, peak hp was probably close to this kit.
The Stage 2 is a bit quieter and with the upper IC hard pipe, the bov sounds like a vta.
The workmanship is awsome on this kit.
I've only driven it under sleep deprivation so I'll need a little more seat time to really compare the differences.
I could see Vishnu should prepping this kit next spring with a clutch, exhaust, cams, the upcoming coilovers, Ferodos, sway bar, undertray, Xede V3 SMART, for a Car and Driver cameo. It looks very stock, clean, and sounds relatively quiet. It will be a supercar slayer. A very nice reliable compromise to the tubular manifold.
Some of us only want to go so far... .
meisnerboy - there were racegas dynosheets posted a week ago. looks very laggy with full boost at 5K rpm, might be due to the restrictive adapter between the turbine housing and the exhaust manifold (the flow doesn't look very good). I'm waiting ofr real results also. I plan on getting the kit with the exhaust manifold to replace the adapter because mechanic says "it looks like a bandaid and it will break". My problem is I want to make 450 and look totally sotck.
Just curious what turbo your using with the vishnu kit...What kind of # did you do on race gas?
3037s with .63 hotside 272/272 cams; 453 whp standard correction Dyno Jet, with inlet air temp around 95 degrees 3rd gearpull. And that was with Alfred pushing the car from behind
Originally Posted by meisnerboy
cough...cough dyno sheet??? cough...
btw Jaylenospoolboy, I live in Studio City. I'd love to see your car.
I have a camera shot of the pulls.
I'm waiting for Chris to send me dyno files but I don't want to push him because he's probably shipping some of my old parts and he worked realllllllllllllly hard yesteday in that heat (and he didn't even yell at me about the burrito).
Note where the guys started the pulls - at 3200 - 3300 RPM. Doesn't look so laggy now, does it....
That one pull at 456 whp was in 4th gear. The rest were in 3rd. Over 350 whp from 4200 rpm to 7850.... hee hee hee
But if you want to replace the best part on the system because your mechanic told you to, go for it.
Shiv
