Stage 2 Turbokit v500
Originally Posted by MorriseySmiths
meisnerboy - there were racegas dynosheets posted a week ago. looks very laggy with full boost at 5K rpm, might be due to the restrictive adapter between the turbine housing and the exhaust manifold (the flow doesn't look very good). I'm waiting ofr real results also.
As others have mentioned, you are talking about lag when it has been clearly stated and proven that the car's kit had JUST been installed and was experiencing a severe wastegate leak. Here are three sets of numbers for you to play with:
July 15: 82 degrees: wastegate leak: 3rd gear pull
RPM WHP/Ftlbs
4000 130/175
4500 190/225
5000 300/315
July 26: 103 degrees: wastegate fixed: 3rd gear pull
4000 155/200
4500 240/280
5000 380/390
July 26: 103 degrees: 4th gear pull
4000 205/270
4500 350/400
5000 390/410
MorriseySmiths -
Here is a better link to view the photo of the dyno runs:
Bigger Photo of Dyno Runs
Originally Posted by Smogrunner
It doesn't even look close to identical in person.
All Vishnu kits use an unadulterated pure Garrett Ballistics turbo. Half the ATP turbo is not Garrett, it is an ATP casted hotside that is not efficient from what all have seen.
Jaylenospoolboy's car made 372whp, 318torque on straight 91 in 103 degree heat. The turbo spooled quickly and held boost.
Not talking down on anyones kit, but I have learned not to believe everything heard over the net.
As far the two not looking similiar, well, it seems thats a matter of opinion, again nothing against anyone.
Originally Posted by shiv@vishnu
Wait till you drive it. Holding turbos equal, it spools up a good 300-500rpm quicker than any other tubular manifold system we've tested (besides the few 1st gen Stg 3 kits we've made last year). It's also *substantially* quieter with none of the high pitched "trumpet-y" ring of tubular header based systems (esp the looong tubed versions). It also looks stock weans a lot to a lot of people. And it also supports 3071s and 3076s without any discernable top-end compromise.
Shiv
Shiv
Originally Posted by statix
Well, we'll see shortly if ATP's kits really suck, from what we have all seen, I refuse to believe that a garrett turbo will behave that differently from kit to kit, only slightly but not worth 2-3k more.
...ATP kits do not perform anywhere close to a full spec Garrett turbo on most of the available kits out there Vishnu, AMS, Full race and so on.
But if you want to see for yourself go right ahead
The lag from the dyno runs two weeks ago was due to a leaky wastegate gasket. With exhaust escaping from the system (pre-turbo), there is less exhaust to spool up the turbo. Without gaskets (leak-free), the Stg 2 30R set-up will make full boost very quickly. On a 5th gear roll-on, we've seen full boost as early as 3400rpm. Much of this quick spool has to do with retaining the factory exhaust manifold and having near perfect wastegate discharge angle (Y-routed in the tubo adapter collar).
Shiv
Shiv
But...
RPM WHP/Ftlbs
4000 130/175
4500 190/225
5000 300/315
4000 155/200
4500 240/280
5000 380/390
4000 205/270
4500 350/400
5000 390/410
RPM WHP/Ftlbs
4000 130/175
4500 190/225
5000 300/315
4000 155/200
4500 240/280
5000 380/390
4000 205/270
4500 350/400
5000 390/410
If you read the discription, it says that those were done with a wastegate leak. I see a 4500 RPM spool up on the dyno, in 3rd gear for the run with the leak fixed. I didn't drive bretts car, but with those dyno results, shiv's notes sound about correct.
Originally Posted by meisnerboy
That is amazing and wonderful and a little hard to believe (I'm not trying to challange you at all but to have full boost so close to stock with a big turbo... well maybe I'm missing something)
But...
makes it look like you aren't getting full boost until around 5000 rpm
But...
Shiv
[QUOTE=statix]Quote:
And yet another opinion, with nothing but he said she to back it up, Thanks for the info......
QUOTE]
If you read through the thread, you'd see I had the ATP kit on my car prior to the stage 2. Andrew's statement of "anywhere close to a full spec Garrett" is a little enthusiastic. The two kits have similar PEAK numbers and both are very strong runners.
The fit and finish of the Vishnu is superior, but these two kits fit different market segments. For someone who wants an inexpensive bolt on (relatively speaking) the ATP kit is a great compromise.
I wanted the stage 3 Vishnu but the reliability of the stock manifold and a quiet stock looking set-up. We compared the dyno graphs of this set up with the stage 3, and under identical environments, we're not so sure there is much of difference if any. Shiv thinks maybe there's 15 or 20 hp on race gas. On 91 there's no difference.
The ATP is not quite the stage 2. It gives up 4-500 rpm on the bottom and tapers off up top compared with the Stage 2.
In a drag race the Vishnu would jump out to a car length by second and pull away through the end of each gear but again that's my humble opinion, but I do own both
If the Vishnu stage 3 is 10/10ths, the Stage 2 is 9.5/10ths and the ATP 8.5 -9/10ths as far as what kind of performance you can pull out of a 3037. IMHO
...ATP kits do not perform anywhere close to a full spec Garrett turbo on most of the available kits out there Vishnu, AMS, Full race and so on.But if you want to see for yourself go right ahead
But...
But...
Just looked at some dyno results today on our dyno computer at the shop. Compared to the ATP 30R kit, our 30R Stg2 kit has a 200ft-lb advantage at 3800rpm and a 50whp advantage at 7000RPM, on race gas. Even on pump gas, the "sweet spot" on the Stg 2 kit is much wider. Most of this has to do with the ATP hotside which gives up efficiency when it comes to spoolup and top end power. This has been proven over and over again on many different cars.
Shiv
Shiv
Originally Posted by plokivos
they look very nice.
i guess that's the stock exhaust manifol with ceramic coat on it? are they ported by chance?
shiv
Shiv
Shiv
I am very impressed. More than likely, I think this is the route I will take when I consider a turbo upgrade.
Do you think that 400 whp (awd dynojet) is feasible on 93 octane pump gas with the typical supporting modifications?
In the long term scope, would you say that the GT3071R is an ideal turbo for a 2.2 stroker revving to 8.0-8.5k on pump?
Thank you for your time in developing this upgrade and catering to our questions.
-Rich
-Rich
-Rich
Why would you want to stroke your motor and then use a 3071? It spools fast on a stock block and can rev to 8k if you want it to. Did you mean a 35R?
