Confused about boost pill.
Old Aug 3, 2005 | 08:02 PM
EvilBlueEvo8's Avatar
ok so here is what is going on. i got an xede v2 from another evom member. i haven't received it yet, but i downloaded xmap, the install directions, maps, etc. i'm reading the instructions and it says to remove the brass boost line restrictor pill which isn't a problem. then it shows instructions for putting in a boost solenoid emulator but it also says only for 2005 evos. i have a 2003 evo. so what do i do? just disconnect the line, remove the pill, and then reinstall the line? are there any parts or lines that i need like it shows? thanks.
these are the links for what i'm talking about:
http://www.vishnutuning.com/evo_install_pill.htm
http://www.vishnutuning.com/evo_install_pill3.htm
Old Aug 4, 2005 | 05:12 AM
gsujeff55's Avatar
all you have to do is remove the line that has the brass pill in it, like the directions say. Take the pill out, and re-install the line.
BUT, what i find to be easier(and MUCH easier if you ever need to go back to the pill) is to just completely replace that vac hose that the pill is in. I believe its a 4mm vac hose, but im not 100% certain.
Old Aug 4, 2005 | 06:05 AM
how long of a line would i need? anyone know the diameter for sure (4mm?)?
Old Aug 4, 2005 | 06:26 AM
gsujeff55's Avatar
i would get 3 ft, just to be safe....you can always cut it, and its like 1 per foot or something.
haxr303
Mar 20, 2016 01:48 AM
Casey Robertson
Jan 29, 2016 03:59 PM
Funsuby
Jun 28, 2012 09:00 AM
PCToolsWiki
Oct 19, 2010 03:09 PM
wrcwannabe
Jun 21, 2007 04:51 PM
