Beta testers needed for Conditional testing
Old Mar 31, 2006 | 09:25 AM
  #31
shiv@vishnu's Avatar
For the time being, you don't need to enable anything. Just update the firmware, import the old maps and see if it runs like normal. jj 008 says it wont go on-line. Does anyone else have this problem. If so, we can figure out where to look.
-shiv
Old Mar 31, 2006 | 05:35 PM
  #32
Anyone else try it?
Old Mar 31, 2006 | 05:42 PM
  #33
chrisw's Avatar
Originally Posted by shiv@vishnu
Anyone else try it?
I will try it tomorrow, I won't be home in time to try tonight.
Old Mar 31, 2006 | 07:01 PM
  #34
Jorge T's Avatar
I get the same flashing orange as jj. Load values register but there seems to be no rpm signal read by xede.
Old Mar 31, 2006 | 07:04 PM
  #35
Jorge T's Avatar
I don't know if this means anything but the text on the map buttons is off. I was only able to update firmware with xmap3.0, xupdate gave error and the 2 newer 3.2 versions did not flash the xede. I'm ready to continue testing.
[both posts edited for typos]
Old Mar 31, 2006 | 07:59 PM
  #36
Ok.... hold off until Monday guys. I need to get you a new file to put in your XMAP folder. Thanks for all the testing so far
Old Mar 31, 2006 | 08:13 PM
  #37
Noize's Avatar
EvoM Administrator
I replied. Couldn't get anything from the firmware link. I need to reinstall SMART on the new harness anyway to utilize this.
Old Mar 31, 2006 | 08:55 PM
  #38
jj_008's Avatar
I had no RPM signal too.
Old Mar 31, 2006 | 08:57 PM
  #39
jj_008's Avatar
I also noticed the wierd text. I couldn't get either version of Xmap 3.2 to update the firmware . I had to use Xupdate.
Old Mar 31, 2006 | 09:15 PM
  #40
Yeah... i'll have to get you guys an updated timing/pattern file. That's why you aren't getting an RPM reading. And also why your XEDE isn't coming on-line with the engine running.
  #41
Jorge T's Avatar
The new Xmap and firmware were attached to my e-mail. Maybe gmail is blocking the attachment?
Old Apr 4, 2006 | 06:38 PM
  #42
Resent with revised Instructions. Give it a shot guys. I tested the update process on a few cars this weekend without any problems. Check yer emails
Old Apr 5, 2006 | 08:07 AM
  #43
Jorge T's Avatar
just flashed the Xede 3 times and still do not get RPM signal and get the offline orange blinking light.
I made sure all previous version were deleted before I re-flased firmware,
I don't know if this is important; but my XEDE will not accept fimware flash from any Xmap 3.2 version, it just stays there asking for Xede reset. No mater how many times turn the ignition on and off it does nothing, with V3.2.0.13 i get an orange blinking light after a few seconds in boot mode during the start of the update process. I can only update firmware with Xmap 3.0. Am I doing something wrong?
Old Apr 5, 2006 | 08:13 AM
  #44
jj_008's Avatar
Same here. The XEDE will not except the firmware using V3.2.0.13.
Old Apr 5, 2006 | 06:34 PM
  #45
Agent-Smith's Avatar
I finally got my xede to update tonight. I had to use XUpdate to update the firmware. Also i had to really flick the car on and off a couple times to get it to go.
Then it was stuck in boot mode. I unplugged the grey connector for about 10 seconds then plugged it back in.
At this point the xede came back online just fine. The new xmap shows the proper software version when i get information from the xede. The buttons for the map names (and on the summary screen) are incorrect and appear as "RT Timing" where it should of course be "Smart Timing". Other than that I am ready for the next step.
