Beta testers needed for Conditional testing
Old Jun 3, 2006 | 05:13 PM
  #76
jj_008's Avatar
Originally Posted by shiv@vishnu
Why do you think i sent he wrong files? They are new. No one other than a couple of people at the shop here run it. It is similar to what I've uploaded in 70 or so cars during the last few tuning trips but with a few bugs fixed.
Shiv
They are exactly the same as the previous email you sent. In your statement above you said to use XMAP 3.2.0_16, but the email version is _13. The timing file is also different then the one you stated above.
Old Jun 3, 2006 | 05:27 PM
  #77
shiv@vishnu's Avatar
ok.. i'll check my outbox when i get home in a couple of hours
shiv
Old Jun 3, 2006 | 07:39 PM
  #78
Yep.. Jeremy was right. I'm an ape. I just resent an email with the new stuff.
Old Jun 3, 2006 | 08:29 PM
  #79
jj_008's Avatar
Still not right. Look at the attachment you just sent . All I got was winmail.dat.
Old Jun 3, 2006 | 08:33 PM
  #80
Jorge T's Avatar
Which one?
Old Jun 3, 2006 | 08:38 PM
  #81
Originally Posted by Jorge T
Which one?
Sorry for being obtuse Ignore the email i sent this morning. The files attached to it were the old ones i sent you a while back. The email I just sent you guys an hour or so ago contain the new files (Xmap, firmware and pattern file).
Old Jun 4, 2006 | 08:02 AM
  #82
Jorge T's Avatar
I caught the old files thing...On my post above I meant what was jeremy referring too since I got the new correct ones, I just wasn't clear on what he meant then and wasn't clear on what I wrote too .
Anyways SUCCESS!
Old Jun 4, 2006 | 09:27 AM
  #83
Jorge T's Avatar
conditional up and running! Bring on the good stuff!
Old Jun 4, 2006 | 10:24 AM
  #84
jj_008's Avatar
I am up and running also. My XEDE goes green after 5 seconds at any RPM though. Also, my knock buffer seems to be malfunctioning. It's reading in the 30's at idle.
Old Jun 4, 2006 | 10:42 AM
  #85
jj_008's Avatar
Oops! I see that my timing file wasn't changed. The knock buffer is still acting funny though.
Old Jun 4, 2006 | 10:48 AM
  #86
jj_008's Avatar
This is in response to those very few customers who have noticed start-up issues (roughness, long cranking, etc,.)
It's funny that you mention this. I had hot and cold start issues since I have had the V3.2 firmware. Last month, I start to have some misfires at boost. My spark plug wires were the culprit so I bought some NAPA factory replacement plug wires. After I changed the wires, my misfires and my hot/cold start issues dissappeared.
Old Jun 4, 2006 | 12:28 PM
  #87
Jorge T's Avatar
My Xede stays orange at idle after startup, when I blip the throttle and rpms go over 1300 light turns green and stays green. All my maps remained intact after burning new firmware. I downloaded the maps and made sure they were OK then reburned them.
Updating the firmware was a biach though. I had to use XMAP 3.0 to update firmware since non of the 3.2 versions inc. Shiv's v_16 refused to reset my Xede in boot mode. It would just stay with the dialog open waiting no matter how many times I would turn the ignition on and off. I even did the config recover thing and still no dice. Oh well after many attemps I got it upgraded with Xmap 3.0.
Old Jun 4, 2006 | 02:04 PM
  #88
Hmm... firmware should update through the new xmap 3.2 just fine. There should be no need to use an older version to conduct the update. Anyone else have problem updating through 3.2? Regardless, glad to hear you guys are up and running with the new goods
Shiv
Old Jun 4, 2006 | 04:27 PM
  #89
jj_008's Avatar
Shiv
I couldn't get it to work either. I had to use Xupdate. I also edited the timing file and am good to go now.
Old Jun 4, 2006 | 06:55 PM
  #90
Cannonballer's Avatar
Shiv
I just updated today and can confirm version 3.2.x does not work. That said, my Xede is fickle about going into boot mode. I could not use Xupdate and version 3.0.x took a few attempts.
