Help with XEDE launch control
Old May 20, 2006 | 05:31 PM
ChrisF's Avatar
I just finally went into the XEDE to take a look at the maps. When Shiv tuned my car he said he set the LC to 6000RPM's. After I hooked up the wire, this works as he promised. I wanted to lower mine a bit, so I downloaded all maps from the XEDE and saw the launch control map. It has only two load columns of 0/100 and only the 100 column has values: -100 from 6500 and higher. Assuming that the negative values begin the LC, I edited the two prior cells of 5500 and 6400 to -100. Uploaded the map, confirmed the changes in the ROM. Started the car and in neutral revved. Still 6000RPM's. What am I missing?
Help?
Old May 20, 2006 | 07:44 PM
jj_008's Avatar
Did you have the clutch pedal to the floor?
Old May 20, 2006 | 08:44 PM
ChrisF's Avatar
Yes my foot is all the way down and per my post, the launch control is working. I have an 03 which doesn't have it built in and my car revs to its new flashed redline of 7850.
Old May 22, 2006 | 10:25 AM
ChrisF's Avatar
Bump.
Old May 22, 2006 | 02:56 PM
Dustin@Vishnu's Avatar
Did you burn the map once you made the change, not just uploaded it?
Old May 22, 2006 | 02:58 PM
ChrisF's Avatar
Yes. Even downloaded it from the XEDE to confirm that it did in fact take.
Old May 31, 2006 | 09:37 AM
ChrisF's Avatar
Bump for answer.
Old May 31, 2006 | 09:42 AM
jrsimon27's Avatar
just do it again and burn it again
Old May 31, 2006 | 11:56 AM
Cajun Power's Avatar
Do It Again, And Burn To Eprom!! ! !
Old May 31, 2006 | 01:53 PM
Jeff_Jeske's Avatar
Be advised that making it below 6k can cause problems when shifting at high RPM.
I had mine set to 5500 and often the rev limiter would catch me on my 1-2 shift.
Old May 31, 2006 | 08:03 PM
I keep bumping mine by resting my left foot on the clutch too much. It will wake you up!
Old Jun 1, 2006 | 02:45 PM
ChrisF's Avatar
I'll try a reburn tonight.
Old Jun 2, 2006 | 07:14 PM
EvoRecordSetter's Avatar
dont change it. 6k is there for a reason, cause its good.
Old Jun 2, 2006 | 08:12 PM
did it work?
